Windows 7 Forums Search
Windows 7 - Problem with Intel Management Engine Interface
09-03-2011   #1
Windows 7 Home premium 64 bit
Everytime I start up the computer and check device manager, there are yellow exclamation marks on my network adaptor and Intel Management Engine Interface error. It says that the device cannot start (code 10). However this all goes away when I restart the computer; but happens again when I "shut down" and turn the pc on again. I have tried formatting windows 7 several times but problem still persists. How can I fix this so that these devices start on my first startup?
i5 2500k
asus p8z68-v pro
windows 7 64 bit
09-03-2011   #2
Windows 7 Home Premium 64 bit
You may want to try re-installing the chipset driver.
09-03-2011   #3
from the motherboard cd? do i have to uninstall the driver and then reinstall? or just reinstall over it?
09-03-2011   #4
Yes, you can just re-install it over the old installation.
Try the driver from here......ASUSTeK Computer Inc. - Motherboards- ASUS P8Z68-V PRO
09-03-2011   #5
unfortunetely problem is still there.. Is this a faulty motherboard or driver related problem?
 Problem with Intel Management Engine Interface problems?
Similar Threads for: Problem with Intel Management Engine Interface
Intel Corporation driver update for Intel(R) Management Engine Interfa Windows Updates & Activation
intel management engine components what is it General Discussion
Solved Intel(R) ICH7 Family LPC Interface Controller - 27B8 Drivers
Intel(R) Management Engine Interface Drivers
Intel Management engine interface Drivers
