Windows 7 - First LED monitor...general appearance question |
09-10-2011
#1 | | |
First LED monitor...general appearance question This seems like the most logical forum for my question, so....
I picked up my first LED/LCD monitor (previously LCD only). It's a 24" 1080p LG and I have messed with all the settings trying to get the darks darker, to no avail. My question then becomes, since I have never even used a LED monitor/TV before, is it normal for the blacks to be almost gray? It wasn't exactly "cheap" so I am assuming it's not an issue with it generally being a crappy monitor...
| My System Specs | | System Manufacturer/Model Number Sony VPCZ1390X CTO OS 7 Pro x64 CPU Intel Core i7-640M Motherboard Sony/Intel Memory 8GB Graphics Card GT330M Monitor(s) Displays Built-in 13" + 24" LG Flatron Screen Resolution 1920x1080, 1920x1080 Keyboard Logitech Illuminated Mouse Logitech Performance MX Hard Drives Internal-2x128GB SSD (Raid 0), 500GB WD Caviar Green
External- 3TB WD Internet Speed 7 MB -- Sprint Overdrive on 4G Other Info Sprint EVO 3D (Synergy 2.3.4) |
09-10-2011
#2 | | |
No, you have a setting wrong, probably the contrast too low and the brightness up.
Normally you just lower the brightness on a LCD/LED monitor and then adjust contrast after the brightness.
We have 4 LED monitors here and they all display nice deep blacks. A Samsung 23", Dell 24", HP 23" and a Viewsonic 21.5". | My System Specs | | System Manufacturer/Model Number HAL-9000 OS Windows 7 Ultimate 64bit CPU Intel i7 2600K @ 4.44Ghz Motherboard Asus P8P67 Pro Rev 3.1 Memory 16GB DDR3 1333 Corsair XMS3 Graphics Card XFX HD5850 1GB EyeFinity Sound Card Logitech G35 & Sennheiser PC135 & VIA HD Monitor(s) Displays 23" HP 2310e, 23" Samsung B2230, 21.5" Viewsonic Screen Resolution 5760x1080 Keyboard Logitech G15 and G13 Mouse Logitech G700 Gaming Mouse PSU Antec True Power New 650watt Case Cooler Master HAF-932 Cooling Corsair H60 Hydro Cooler, 3x 230mm Fans, 2x120mm Fan Hard Drives 16TB of Storage
128GB & 256GB Crucial M4 SSD's, 2X 1TB WD Black, 3x 2TB WD, 3x 2TB Samsung F4, 1.5TB Seagate, WD 500GB, Internet Speed 50/10 Mbit Other Info Speakers : Alesis M1 Active Mk2 Studio Monitors , APC RS 1200 UPS, HP 4500DN Color Laser, HP P1006 mono Laser, Kodak 8500 Dye-Sub, Epson 1280 inkjet, Epson Worforce 610 MFC |
09-10-2011
#3 | | Windows 7 Professional 64 Bit |
When you refer to "all the settings" do you mean just the menu settings on the LG monitor? Have you tried adjusting via the NVIDIA Control Panel as well? | My System Specs | | System Manufacturer/Model Number Custom Build OS Windows 7 Professional 64 Bit CPU Intel QX9650 - Mild Overclock to 3.5Ghz Motherboard ASUS P5Q SE Plus Memory 16GB G.Skill F2-6400 at 840Mhz Graphics Card nVidia Ge Force 9600GT Sound Card On Board Monitor(s) Displays HP w2408h Screen Resolution 1920 x 1200 Keyboard Logitech Illuminated Mouse Logitech Wireless Trackball M570 PSU Antec Basiq BP500U Case CoolerMaster ATX ATC-210 Cooling Non-Stock Heatsink w/high speed CPU fan Hard Drives CRUCIAL M4 128Gb SSD, --
Two - WDC WD1001FALS-00J7B0 SATA's, -- One
WDC WD2001FASS-00U0B0 SATA |
09-10-2011
#4 | | |
My LG LED 23"'s came with crazy bright settings. Also what are you using to connect it HDMI, Display port, Mini D. or DVI? I set my pair of LG's up with HDMI and Display port and I've been very pleased. I could tell you my settings but really every room, GPU and eye are different so what's working for me could be horrible for you. Good luck and keep fooling around cause the perfect setting is there. | My System Specs | | System Manufacturer/Model Number A blend of brains, brawn and dumb luck ! OS Windows 7 Ultimate 64 CPU AMD 965 Phenom II X4 3.4 BE, OC'd stable at 4.1 Motherboard MSI 890FXA-GD70 Memory 16 gb G. Skill Z Series 2133 DDR3 9-10-9-28 @ 1866 Graphics Card (2) Crossfired MSI R5770 Hawk's OC'd Sound Card On board HD audio with lossless 24 bit/192 sample rate Monitor(s) Displays (2) LG LED 23" 1920 x 1080 2ms Monitors via hdmi/d-port Screen Resolution 1680 X 1050 p Keyboard (2) Logitech Illuminated Keyboards (1) usb (1) wireless K800 Mouse Logitech G9x & T-BC21 - nano nx for the laptop PSU Ultra X4 modular 1050 watt 80% silver rating & APC 1200 RS Case Thermaltake Element V Black Edition Cooling 15 case fans w/speed control,Corsair H100 in P/P, gpu fans Hard Drives (2) 128 gb Crucial m4 SSD drive sata III
(2) 1 tb Hitachi deskmates/sata
(1) 1 tb WD green/sata
(2) 2 tb WD My Book/esata
(1) 500 gb Seagate Freeagent/esata
(2) 250 gb Seagate Freeagent go's/usb
(1) 80 gb Seagate Barracuda/sata
(1) 64 gb Crucial C300 Internet Speed Some where between the worst and bearable Other Info 3 Noctua fans + 4 Noctua in p/p on H100 cooler
Ultra 2.5 dual hot swap drive bays for SSD's
(2) Lite-on dvd/cd optical 22X
Ultra MD3 media reader, IO ports & fan controller
HP Officejet Pro L7680 all-n-one
HP 4 laserjet (the beast)
Hot swappable 3.5" hard drive bay
Belkin Play N600 HD router
Asus USB 3 & sata 6 PCIe card
HP Probook i3 laptop |
09-10-2011
#5 | | |
Thanks for the responses...Clearly I need to work on the settings a little more. Not sure how much I can do with the NVIDIA control panel.
I have the brightness turned all the way down.
Yes, I am hooked up via HDMI. | My System Specs | | System Manufacturer/Model Number Sony VPCZ1390X CTO OS 7 Pro x64 CPU Intel Core i7-640M Motherboard Sony/Intel Memory 8GB Graphics Card GT330M Monitor(s) Displays Built-in 13" + 24" LG Flatron Screen Resolution 1920x1080, 1920x1080 Keyboard Logitech Illuminated Mouse Logitech Performance MX Hard Drives Internal-2x128GB SSD (Raid 0), 500GB WD Caviar Green
09-10-2011
#6 | | |
I'm radeon 5770 but my LG settings are:
Brightness 47
Contrast 46
Sharpness 6
Color Temp - Preset - 6500
Gamma 0
Just FYI | My System Specs | | System Manufacturer/Model Number A blend of brains, brawn and dumb luck ! OS Windows 7 Ultimate 64 CPU AMD 965 Phenom II X4 3.4 BE, OC'd stable at 4.1 Motherboard MSI 890FXA-GD70 Memory 16 gb G. Skill Z Series 2133 DDR3 9-10-9-28 @ 1866 Graphics Card (2) Crossfired MSI R5770 Hawk's OC'd Sound Card On board HD audio with lossless 24 bit/192 sample rate Monitor(s) Displays (2) LG LED 23" 1920 x 1080 2ms Monitors via hdmi/d-port Screen Resolution 1680 X 1050 p Keyboard (2) Logitech Illuminated Keyboards (1) usb (1) wireless K800 Mouse Logitech G9x & T-BC21 - nano nx for the laptop PSU Ultra X4 modular 1050 watt 80% silver rating & APC 1200 RS Case Thermaltake Element V Black Edition Cooling 15 case fans w/speed control,Corsair H100 in P/P, gpu fans Hard Drives (2) 128 gb Crucial m4 SSD drive sata III
09-10-2011
#7 | | Windows 7 Professional 64 Bit |
Quote: Originally Posted by awenthol Thanks for the responses...Clearly I need to work on the settings a little more. Not sure how much I can do with the NVIDIA control panel. You can do a lot with the NVIDIA Control Panel. Be sure to tick "Use NVIDIA Settings". I don't use the Windows "Calibrate Display". I didn't care for the results I got when I tried it. Of course my monitor is not the same as yours - it's an HP w2408h LCD. | My System Specs | | System Manufacturer/Model Number Custom Build OS Windows 7 Professional 64 Bit CPU Intel QX9650 - Mild Overclock to 3.5Ghz Motherboard ASUS P5Q SE Plus Memory 16GB G.Skill F2-6400 at 840Mhz Graphics Card nVidia Ge Force 9600GT Sound Card On Board Monitor(s) Displays HP w2408h Screen Resolution 1920 x 1200 Keyboard Logitech Illuminated Mouse Logitech Wireless Trackball M570 PSU Antec Basiq BP500U Case CoolerMaster ATX ATC-210 Cooling Non-Stock Heatsink w/high speed CPU fan Hard Drives CRUCIAL M4 128Gb SSD, --
WDC WD2001FASS-00U0B0 SATA First LED monitor...general appearance question problems? All times are GMT -5. The time now is 11:23 AM. |  |
