Solved Laptop Battery - Plugged in, not charging.
205tim
Power User
9:19 PM
As per the thread title, the battery is recognised as being present, but is not charging, and when the power is disconnected, will not run on battery power. I have come to the conclusion that it is most likely a hardware issue, see below.
  • Comptuer is the one in my 'System Specs', just on 2 years old, out of warranty period.
  • I have checked the battery connections and visually all is in order.
  • I have searched, and applied what appears to be a common fix for this, but did not change the situation;
  • >Disconnect AC
    >Shutdown
    >Remove battery
    >Connect AC
    >Startup
    >In Device Manager, Under the Batteries category, right-click all of the Microsoft ACPI Compliant Control Method Battery listings, and select Uninstall >Shutdown
    >Disconnect AC
    >Insert battery
    >Connect AC
    >Startup
It runs normally using the power cord, so I am thinking that it is an issue with either the battery or something more sinister, within the computer/motherboard, as it was fine one moment, but not the next.
Prior to this the battery would last approx. 2 hours, and HW moniter showed it had around 30% wear, now shows 56% wear.
I have never had a battery suddenly die like this, but am thinking it is a distinct possiblity given the symptoms. Should I bite the bullet and order a new battery and hope that this is the fix? or is there likely a solution I have not come across?
Thanks in advance, Tim.
7 Home Premium x64Core 2 P8700 2.53ghz4gb DDR2Nvidia GeForce 105M
HP Dv3-2137tx
7 Home Premium x64
Compaq
4gb DDR2
Nvidia GeForce 105M
13" 1366x768
500gb 5400rpm
Buying a new battery is an expensive way to test but it may be the only way unless you have a multi tester and can test your battery. Two hours seems like a very short time for a laptop to run on a full charge unless you are playing videos constantly.
I have had this issue with a MacBook Pro and it turned out to be a 4 pin connector under the keyboard that was faulty.
Windows 7 Professional 64bitIntel Celeron 2.4 GH4 GBNVidia GeForce 9800GT
MSI
ATI HDMI Audio
Acer S231HL Dual Monitors
Hitachi 300GB ATA
Maxtor 300GB USB
Standard
Logitech wireless
Logitech wireless
Cable
Thanks Roban, I agree that buying a new battery is an expensive way of testing this, and also that two hours is not particularly long battery life. That is usually listening to music while using the 'net and running a few office type applications etc.
I'll wait and see if anyone else has ideas, but I have found a battery for $60 shipped to my door with warranty and so on, so will give this a try if necessary.
Tim
HP Dv3-2137tx
7 Home Premium x64
Compaq
4gb DDR2
Nvidia GeForce 105M
13" 1366x768
500gb 5400rpm
Windows 7 Professional SP1 32-bitIntel Core 2 Duo E6600 2.4GHz4GB DDR2-667 (4x1GB in dual-channel config)nVidia GeForce 9800 GT
Custom-built
Asus PL5D2
Creative X-Fi XtremeMusic
Acer P236H
1920x1200 (DVI)
OCZ SSD Vertex Plus 60GB SATA (Firmware 3.55), 64MB cache
Hitachi HD321KJ SATA, 320GB, 7200rpm, 16MB cache
Antec TruePower 2.0
Cooler Master Centurion
Too many fans
Standard
Microsoft wireless optical mouse
AT&T U-verse (18mbit/sec)
Other devices:
Compaq CQ-60 laptop
Google Nexus 7 (2012) tablet
Nvidia SHIELD tablet (US/LTE)
Hardkernel ODROID-XU single-board computer (Samsung Exynos 5420)
I shall order a replacement battery, as I suspected I might need to, and let you know the outcome when it arrives. Thanks all.
HP Dv3-2137tx
7 Home Premium x64
Compaq
4gb DDR2
Nvidia GeForce 105M
13" 1366x768
500gb 5400rpm
many moons ago i had an old NEC i-select M5210 (cant believe i remember that!)
after a couple of years it developed a quirk like yours where it wouldnt charge. i popped in another battery as i had 2 laptops, and it still happened, yet the one from mine would charge when in the other laptop.
I took it apart to investigate the problem, and it was a dry joint on the jack socket for the charger. was only one of the 4 joints.
a bit of soldering later and it was happy.
on an after thought, use a multi meter to test the terminals on the laptop when its on. 2 of the 3/4 pins together should be kicking out 19v to the battery when plugged in.
Windows 7 Ultimate x64, & Mac OS X 10.9.2Intel Core i5 2500kCorsair Vengence 8gb 1866mhzNvidia GTX 770 OC
Built by badgers!!!
Intel Core i5 2500k
Asus P8z68 LE
Nvidia GTX 770 OC
2x ASUS LED 22" IPS
3840x1080
240GB Crucial M500 SSD
120gb Corsair Force 3 SSD
1TB Western Digital
Corsair HX650w Modular
Corsair Air 540
Corsair H60 Push/Pull
Corsair K70/ Logitech G27 wheel
Saitek R.A.T 9
Too slow!
AMD fusion E350N Home server-Windows Home Server 2011 (also made by badgers!)
2011 Macbook 2.4ghz Core2Duo, 4gb ddr3, 120gb Ocz Vertex SSD
Thanks Badger, I will try to track down a multimeter to borrow. In the mean time, I have ordered a battery, and will see what the outcome of this is before opening up the computer.
HP Dv3-2137tx
7 Home Premium x64
Compaq
4gb DDR2
Nvidia GeForce 105M
13" 1366x768
500gb 5400rpm
Just to follow this up, my new battery just arrived, and the source of my problems was indeed the battery. Definately a better outcome than it might have been so I'm happy.
Thanks to all who helped/confirmed my thoughts.
Tim
HP Dv3-2137tx
7 Home Premium x64
Compaq
4gb DDR2
Nvidia GeForce 105M
13" 1366x768
500gb 5400rpm
finall found the solution to "plugged in not charging"
Finally after 4 hrs of research found the solution
1. go to control pannel
2. click on power options
3.left hand side click on 4th or 5th point which says " Choose when to turn off the display"
4. bottom left click on " Change advance power setting"
5.click on "Energy management" tab(mine is lenovo so the second tab next to "Advance Settings" says "Lenovo Energy Management"
6. in the middle click on "Energy management Tab"
7. Bottom Right is a circular icon move ur mouse over it which says"Click to change power scheme" Click on it
8. Finally click on "optimize for battery runtime" click apply and then on OK and ur problem is finally sorted.
Windows 7 Home Premium 32bit.
A 56% capacity loss is rather much... but you might install Osiris Development - BatteryBar, the most accurate battery meter for Windows which is a nice tool to give you a lot more details about your battery than Windows' own power icon does.
I have tried many times to try and sort out the "battery plugged in not charging" and I have installed it into my spare laptop which I use for testing purposes it is an (HP 510 running Windows 7 Professional 32 bit Service pack 1) So I downloaded this Osiris and now instead of getting "battery plugged in not charging" I now get the following information as seen in the attached Google Drive: Sign-in
Windows 7 64bit Service Pack 1Intel Core 2 Quad Q8300 @ 2.50GHz8.00GB Dual-Channel DDR3 @ 666MHzV223W (1680x1050@59Hz) 1023MB NVIDIA GeForce ...
Custom build
ASUSTeK Computer INC. P5E3 Premium (LGA775)
V223W (1680x1050@59Hz) 1023MB NVIDIA GeForce GT 430 (NVIDIA)
NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Acer 22"
X193HQL (Analog)
Seagate 2.0TB
ST2000DL003-9VT166 ATA Device
700W
Akassa heatsink and two coolingfansg
Kaspersky Internet Security 2019
IE 11
Will be undertaking a total upgrade from the case upwards next year.
Case, motherboard, ram, cpu and last but not least a 2TB SSD, but before I do that everything will be backed up to the cloud
....I now get the following information as seen in the attached Google Drive: Sign-in
I'm not prepared to create a Google account just so I can sign in and see whatever it is that you put there.
Either make it publicly visible, or (preferably) post it as an attachment here rather than on Google Drive.
    Windows 7 Home Premium x64AMD V1204GB
    Toshiba satellite C650D
    AMD V120
    4GB
    150 Mbps
    IE11, Edge, Firefox
    I also have W7 Pro on my System Two, and several W7 Hyper-V VMs. My other machines run Windows 10/11. Their specs are in my Ten Forums & Eleven Forum profiles.
    Windows 7 Pro x64Intel i5-3320M8 GB
    Lenovo Thinkpad T430
    Windows 7 Pro x64
    Intel i5-3320M
    8 GB
    250GB Samsung SSD 860 EVO
