After Pc Case dropped about 3 feet fails to power-up
  1. Posts : 140
    While servicing my desktop I inadvertently let the case drop a distance of about 2 feet. Now when I attempt to power it up nothing happens - no fan spin-up , only one little led light illuminates on the m/b.
    I realise that to remedy this situation will involve a process of illimination and to get me started on this I would be grateful if anyone could reply to 2 questions I have initially.
    1. Is it possible to trouble shoot the performance of the m/b here or , at least , illiminate m/b damage from the cause of the PC failure to boot here?
    2. Is it also possible similarly to isolate the existence of any damage to the power supply?
  2. Posts : 72,052
    Hello Thenoo,
    While unplugged, you could open the case up and double check for any obvious signs of damage. Next, check to make sure that all cards, memory, CPU, etc.... are still firmly seated in their motherboard slots. Also, double check to make sure that all data and power cables are still firmly connected, and that the motherboard is not grounding out. Afterwards, see if it may power up.
    If all of the above checks out, then you may need to take it to a computer repair shop to have it checked out if you do not have any spare parts to swap out to test with.
    I hope it's something simple.
  3. Posts : 140
    I've now got everything working again. First thing I discovered was the reason for the completely dead PC. I didn't mention this in my OP but my problems started when I damaged my original graphics card by snapping off the externally protruding DVI/VGA adapter . I then attempted to replace this with an identical card which caused lots of problems as this card like the original , was too big for my case - fitting it into the slot was extremly difficult and this one also got damaged but the strugling to plug it into the m/b displaced the little power connection without my noticing this - hence the "dead " PC ! once I pluged this back in I got normal spin-up of all the fans but still no graphics. I was now convinced the problem was a damaged m/b but , after replacing the 2nd card with a physically smaller one , I got everything back to normal again.
  4. Posts : 72,052
    That's great news Thenoo. I'm happy to hear that you got it working again. :)
