Problem in PC not booting-up after new cooler installation
  1. Posts : 321
    Windows 7 Home Premium SP1 64-bit
    I bought a new cooler and a new atx case after moving my PC to my new case and installing my new cooler my PC wont start... well my PC still runs, fans, gpus, cpu fans, led lights etc. only my monitor and keyboard & mouse lights wont start, I also tried using a different monitor but to no avail... any ideas?
  2. Posts : 4,161
    Windows 7 Pro-x64
    Are you getting any beep codes? I'd try reseating the GPUs, memory and check all your power cables.
  3. Posts : 321
    it doesnt beep, might i have fried my cpu if i accidentally put the cpu-fan connector to my motherboard the opposite way?
  4. Posts : 4,161
    Windows 7 Pro-x64
    If no beep(s), you're not completing POST. That generally equals hardware problems. I don't know about the fan; I thought the connectors fit only one way but I doubt it hurt the MB. Worst case is it fried the RPM inductor in the fan. Or you broke a trace.
    Did you recheck all power connections and the GPU cards?
  5. Posts : 321
    Yes I have reseated the gpus and rams it still runs and no beeps but still no monitor... both of my gpu fans works too when I boot up my system I'll try checking the cables now
  6. Posts : 4,161
    Windows 7 Pro-x64
    Did you connect the CPU power shown in the sqare?
    Attached Thumbnails Attached Thumbnails Problem in PC not booting-up after new cooler installation-asus-p6t-delux-v2.jpg
  7. Posts : 321
    Yes I have connected cables, the motherboard lights up, the fans run.. but still nothing happens.
  8. Posts : 321
    Also when I turn on my PC my Antec Kuhler 920 led lights up red (the logo attached to the cpu is supposedly to have led) then turns off, is it supposed to do that?
  9. Posts : 321
    got it sorted out thanks guys
  10. Posts : 1,846
    Windows 7 Ultimate x64, & Mac OS X 10.9.2
    Was it that you didn't connect the 4/8 pin pci express 12v supply?
    Sent from my BlackBerry 9900 using Tapatalk
