Windows 7: CD drive doesn't work after being in water! :(
21 Nov 2011   #1
Hello,
I am new to SevenForums, and I was looking for some help.
In my neglect, I accidentally put my Dell laptop on the rug in my basement. My basement flooded a day later. Everything works fine except for my CD drive. When I put a CD or DVD in the drive, it makes a whirring sound, then it stops. I look in My Computer and it says that there is no CD in the drive. Any help would be greatly appreciated. Thanks.
DrummerDan99
System Specs:
Dell Vostro 3550 with Windows 7 Home Premium x64
2.10 GHz Intel Core i3-2310m
8.00GB RAM
DVD Drive: PLDS DVD+ RW DS 8A5SH
21 Nov 2011   #2
Your whole system got completely submerged with the battery in and thats the only fault? I'm amazed already!
All I can suggest is trying to dry it out longer by removing it and opening it (either before shutdown or with the emergency eject hole and a paperclip) and putting it somewhere warm (not above 70C). Secondly cleaning the lens could help.
I would hope you have insurance on this as I would expect to hit a lot more problems.
21 Nov 2011   #3
The battery didn't work at first, so I had to take the battery out and put it into a bag of rice for a few days, then it managed to keep working. Thanks for the CD drive tip. I'll try it and reply.
21 Nov 2011   #4
Microsoft MVP
Windows 7 Ultimate X64 SP1
I would suggest leaving the battery out and putting the entire laptop in rice with the CD tray open for about one week. Carefully shake out all the grains before applying power.
21 Nov 2011   #5
Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
Quote   Quote: Originally Posted by DrummerDan99 View Post
I'd even suggest putting the entire laptop in a large bag of rice to continue and speed the drying process. Was the entire laptop totally submerged as stated by another poster, or did it just get wet?
21 Nov 2011   #6
Windows 7 Ultimate x64, & Mac OS X 10.9.2
can always take out the drive and place it in the oven at about 40c for a few hours.
Before anyone says thats stupid lol its not, places on our planet often exceed 40c as do computer components.
Its been tried and tested with mobile phones in the past, could also use a hairdryer lol
21 Nov 2011   #7
windows 7 64 bit premium
I know a fella who dryed out his mobile phone by putting it on the end of his car exhaust!
idea?
21 Nov 2011   #8
Microsoft MVP
Quote   Quote: Originally Posted by sinbin View Post
idea?
Absolutlely not! Way, way too hot. Poor idea!
Quote   Quote: Originally Posted by badger906 View Post
Another poor idea! there are places on the planet where electronics won't function as well.
21 Nov 2011   #9
I'll go with the hair dryer on medium heat. On high hold it at least eight inches from the CD/DVD drive.
Use a lens cleaner disc if it ever decides to work. A new CD/DVD drive is only about $20 if that one is dead.
21 Nov 2011   #10
Windows 7 Ultimate 64bit
Ok firstly stick your head in a bag of rice and wait for your brain to dry out, why on earth did you leave your laptop on a rug in the basement of all places
But all joking aside pal take Hopalong's advise and invest in a new DVD drive. Even USB external ones aren't to expensive
Similar help and support threads for2: CD drive doesn't work after being in water! :(
External USB DVD Drive doesn't work on 3 machines but works on my XP Hardware & Devices
Virus formatted Hard drive and Key used Doesn't work Windows Updates & Activation
External hard drive doesn't work with W7,64bit Hardware & Devices
External Drive doesn't work after latest updates Windows Updates & Activation
Autorun Doesn't Work; External Drive Always Pops Up Hardware & Devices
Flash drive doesn't work Hardware & Devices
IDE Hard drive doesn't work?? Installation & Setup
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
