According to their website that product carries a lifetime warranty. Send it back and get another.
OCZ Rally2 USB 2.0 Flash Drive - OCZ
quick grab it from the landfill
thanks a lot for that 1foxracing.
it actually says "limited lifetime warranty" - not sure what that means, i'll investigate further.
+rep for you
hang on, i'm just scraping off all the cat food and coffee grinds from it first....
disk management just hangs at 'connecting to virtual disk service' if i start it with the drive plugged in.
if i start diskmgmt without it plugged, then plug, then refresh or rescan, the little blue circle spins and spins to no avail.
