Will the Pc1x1 connection limit the speed of this Device
kodi
Geriatric Member
8:53 AM
Sydney, Australia
Windows 10 Pro x64i7-4770K16Gig DDR3-2400Gigabyte GT740
Self Built Custom Computer.
i7-4770K
Asus Z87 Sabertooth
16Gig DDR3-2400
Gigabyte GT740
Onboard
Benq 27" - Dell 23' - Benq 22"
Samsung 840 Pro 128g SSD
1xWestern Digital Caviar Green 1tb
2xWestern Digital Caviar Green 2 tb
Seasonic 760 watt Platinum
Coolermaster Haf - X
Noctua NH-C12P CPU Cooler
Logitech illuminated keyboard
Logitech Perfomance MX
Cable = speeds to 20Mbps downsteam and 512kbps upsteam
Avast Internet Security
It really depends on the drive(s) you are connecting to it. The PCIE-1x slot if (1.0) will have a single direction max rate of aprox 266MB/s and if (2.0) 532MB/s.
This will be fine for 7200rpm Hard Disks but if you were planning on one or more 500MB/s SSD's then the bus-width would limit you.
The devices only claim to be compatible with a PCI-E x1 (2.0) interface.
Windows 7 Ultimate x64Intel Core2 Quad Q8300 2.5GhzKingston HyperX 4x1GB DDR2 1066MhzAsus/Nvidia 9500GT 1GB
Self Build
Asus P5QD Turbo
On-Board HD
22" Widescreen TFT
2x 320Gb Seagate SATAII RAID 0
2x 80Gb Seagate SATAII RAID 0
1x 1tb hybrid (8gb ssd)
650w
ATX
140mm front, 120mm Rear, 80mm Chipset + stock CPU and GPU
Plastic one
Plastic one
4Mbps
Laptop: HP Elitebook 2560p
i5 @2.7Ghz 4GB DDR3
It's confusing because the Manufacturer claims that if you use a PCIex1slot you can obtain PCIex2 speeds (sata3),is it possible the card boosts the speed
i7-4770K
Asus Z87 Sabertooth
16Gig DDR3-2400
Gigabyte GT740
Onboard
Please link to where it claims this?
It has 2x Sata III ports on it. But cannot transfer data across the board faster than the max speed of a single PCIE lane.
Depending on the controller on the card, two drives using it may well be able to transfer at full speed between each other.
EDIT: It wouldn't be the first device to be sold with a bottle neck.
Self Build
Asus P5QD Turbo
On-Board HD
22" Widescreen TFT
650w
ATX
Plastic one
Plastic one
4Mbps
i5 @2.7Ghz 4GB DDR3
