Will putting a DDR 2 667 MHz RAM with a 533 MHz cause problems?
UdAkDev
10:53 AM
I am planning to upgrade my system from 1 GB to 2 GB. Currently I have a DDR 2 533 RAM card of 1 GB. I am planning on putting another 1 GB RAM card, but it's a 667. What are the problems that will come? Can automatic reboots happen?
Also, IF I put a 1 GB 533 MHz RAM card instead of a 667 one, will THAT cause any problems as well?
Windows 7 Ultimate 32-bitNVIDIA GeForce 8400
HP
NVIDIA GeForce 8400
SATA 500 GB
If in dual channel the slower module speed will be used. :cool: But the answer is no, you should have no problem.
But will be best to keep the module speeds the same.!!
Seven ultimate 32bitCore2Duo E57003GB DDR2HD5670
Asus
Core2Duo E5700
Asus p5qlem
3GB DDR2
HD5670
Onboard
Philips 18.5 widescreen
Depends
500GB Samsung 7200RPM
500w Sparta
Aerocool
Standard + 2x 40's inserted
Multimedia
Genius
10meg.
Thanks man! But I'm not sure about dual module - what does that mean?
HP
NVIDIA GeForce 8400
SATA 500 GB
You mean dual channel? Read THIS
Asus
Core2Duo E5700
Asus p5qlem
3GB DDR2
HD5670
Onboard
Depends
500w Sparta
Aerocool
Multimedia
Genius
10meg.
Windows 10 Pro x64, Arch LinuxIntel Core 2 Quad Q8200 OC'd 3.08GHz8GB DDR2 900MhzMSI GT730 2GB GDDR5 (Kepler)
Asus Rampage formula LGA775
8GB DDR2 900Mhz
Supreme FX2
Samsung LS22F350 LED
1080P
Kingston SSDNow UV400 120GB, 500GB Hitachi, 2TB Samsung, 500GB Seagate FreeAgent, 640GB Samsung, 160GB Toshiba (Arch)
AeroCool 500W Bronze
Cooler Master V6 + 3X fans
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
Single and dual channel mode refer to the effective memory bandwidth.
Single Channel Mode: Here, only one stick of RAM is installed. So long as it is supported by your system (and most should be, if they are physically compatible), the stick will work. The effective memory footprint will be 64-bits wide.
Dual Channel Mode: Here, two sticks of RAM are installed. Again, so long as they are supported by your system they should work and provide double the memory footprint, i.e. 128-bits wide. However, it is not necessarily as easy as that. The memory will only operate at the highest common speed, so a module rated at 667MHz coupled with one at 533MHz will run at the slower speed of 533MHz. In addition to that, timing issues play a part. Ideally, the timing values should be identical. For best results, it is recommended that identical modules should be used in such setups.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Will non-identical DDR 2 RAMs cause automatic reboots from time to time?
HP
NVIDIA GeForce 8400
SATA 500 GB
If both modules work fine you should have no problems.. ;)
Asus
Core2Duo E5700
Asus p5qlem
3GB DDR2
HD5670
Onboard
Depends
500w Sparta
Aerocool
Multimedia
Genius
10meg.
Thanks man! Both modules working fine means that the system should reboot :-) But what if I play a game like Harry Potter 4? When the screen blackens momentarily before going to the game, or when I'm half-way playing it, will there be a sudden reboot? What are the causes for automatic reboots anyway :-)?
HP
NVIDIA GeForce 8400
SATA 500 GB
Asus
Core2Duo E5700
Asus p5qlem
3GB DDR2
HD5670
Onboard
Depends
500w Sparta
Aerocool
Multimedia
Genius
10meg.
Thanks man!
HP
NVIDIA GeForce 8400
SATA 500 GB
