right click problem
  1. Posts : 36
    win 7 64bit
    right click problem
    hey guys, i`m having issues with my mouse. the problem is when i got to right click to save a image or open a link in a new tab the right click does nothing. if i click a link with the left button sometimes it will open in a new tab. if i right click in my favourites it will work so i can open page in a new tab. it works fine on my desktop it just happens for saving online images and online embedded links.
    i`ve run spyware scans and virus scans as well as restarting my pc and restore point but it does nothing. i`ve looked on my mouse settings and can see anything wrong there but it seems i`m missing something.
    any help would be great
  2. Posts : 15,026
    Windows 10 Home 64Bit
    are you sure its a problem with the mouse? have you tried using another mouse?
    which browser are you using?
    also try this SFC /SCANNOW Command - System File Checker
  3. Posts : 36
    win 7 64bit
    just waiting on the scan to finish, i`m running on the new ie9 and i`ve tried 2 different mouses now and thats the same. do you think it could be ie9 related?
  4. Posts : 15,026
    which antivirus are you using
  5. Posts : 36
    win 7 64bit
    i`m using webroot antivirus and search and destroy antispyware
  6. Posts : 15,026
    I'd suggest you to do a full scan with Microsoft Security Essentials - Free Antivirus for Windows
    and post back results
  7. Posts : 36
    win 7 64bit
    ok i`ll give that a go
  8. Posts : 15,026
    well yes it could be a problem with ie9 but lets not get there now
    do you have the any problem while using firefox or chrome?
  9. Posts : 36
    win 7 64bit
    scan completed and nothing was found
  10. Posts : 36
    win 7 64bit
    i don`t really like firefox or chrome, maybe it`s because i`ve not given them time and i`m just so use to using ie
