right click problem
carlnw1975
2:01 AM
nottingham,uk
hey guys, i`m having issues with my mouse. the problem is when i got to right click to save a image or open a link in a new tab the right click does nothing. if i click a link with the left button sometimes it will open in a new tab. if i right click in my favourites it will work so i can open page in a new tab. it works fine on my desktop it just happens for saving online images and online embedded links.
i`ve run spyware scans and virus scans as well as restarting my pc and restore point but it does nothing. i`ve looked on my mouse settings and can see anything wrong there but it seems i`m missing something.
any help would be great
win 7 64bit
win 7 64bit
gigabyte
Windows 10 Home 64BitIntel Core i5 10400 @ 2.90GHz8.00GB Single-Channel Unknown @ 1329MHz (16-2...
Self assembled
Intel Corporation DG41WV (PROCESSOR)
8.00GB Single-Channel Unknown @ 1329MHz (16-20-20-38)
DELL E170S
1280x1024 pixels
931GB TOSHIBA DT01ACA100 (SATA)
238GB TEAM TM8PS7256G (SATA SSD)
Nothing Fancy
Fans
A4 Tech Co LTD
A4 Tech Co Ltd/Logitech
25 Mbps
just waiting on the scan to finish, i`m running on the new ie9 and i`ve tried 2 different mouses now and thats the same. do you think it could be ie9 related?
win 7 64bit
win 7 64bit
gigabyte
which antivirus are you using
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
i`m using webroot antivirus and search and destroy antispyware
win 7 64bit
win 7 64bit
gigabyte
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
ok i`ll give that a go
win 7 64bit
win 7 64bit
gigabyte
well yes it could be a problem with ie9 but lets not get there now
do you have the any problem while using firefox or chrome?
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
scan completed and nothing was found
win 7 64bit
win 7 64bit
gigabyte
i don`t really like firefox or chrome, maybe it`s because i`ve not given them time and i`m just so use to using ie
win 7 64bit
win 7 64bit
gigabyte
could you just try using one of them to see if the same problem appears :(
* Delete all the history + Reset all zones to default level
* You could also try the reset options in >internet options>advance.
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
just tried firefox and it save images etc so looks like the problem is with ie9
win 7 64bit
win 7 64bit
gigabyte
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
yeah just done the reset option and still nothing happens, thing of going back ie8
win 7 64bit
win 7 64bit
gigabyte
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
tried reinstalling it and even tried ie8 and it`s happening on that too now. this is very strange
win 7 64bit
win 7 64bit
gigabyte
maybe there's a registry fix for it,.. im not sure.
are you still using ie or using FF for the time being?
edit: may i know what error message do you receive when trying to save the image? or is the save image option greyed out?
you could also check this http://support.microsoft.com/fixit/ link and see if it solves any of your problem :(
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
still no go, tried a reg fix and still the same thing happening, so i`m gonna keep on using firefox now i`ve transfered my favorites from ie. thanks for your time and help koolkat77
win 7 64bit
win 7 64bit
gigabyte
hmm :( so the mystery remains unsolved. well anyway, hope someone sees this post and got a valid fix for it & enjoy your new browser :).
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
