Windows 7: Strange constant flicker on LCD Monitor - help?!
01 Jan 2012   #11
seekermeister
Is it possible for you to disconnect the PC from the monitor and attach something else (like a DVD player) that would send a video signal to the monitor to determine if the flicker continues? That way you could be sure if the problem is actually in the monitor, or the PC. Even if not, it would be interesting to know if the flicker appears on the black screen without a picture. You could also open the monitor settings so that an image would be on the screen.
02 Jan 2012   #12
DeniqueCoelum
Windows 7 Professional x64 SP 1
Quote   Quote: Originally Posted by A Guy View Post
Do you see the issue on the monitors own internal On Screen Displays (OSD)? The menu for instance. If the monitors own menu displays correctly, then it is a video problem (source). It is unlikely to be bad caps, especially on a one year old monitor. The major cap problem was limited to an older production run (see Capacitor Plague).
In a television, a steady rate horizontal or vertical scrolling would point to a bad ground or video interference due to shielding issues. If you can connect the monitor to another PC, you can quickly determine if it is the monitor or the PC. I believe a horizontal scrolling would be less likely with a monitor failure.
A Guy
I'm not sure! I'll certainly check that. Weirdly (and also mildly annoyingly), I haven't noticed the problem occurring since I started this thread!
Quote   Quote: Originally Posted by bassfisher6522 View Post
Thanks! I'll check that out when I next get the problem, see if it helps!
Quote   Quote: Originally Posted by Heyyou View Post
Just a guess, but when you mentioned playing games, I immediately thought of the video card not being large enough.
My video card details are on my spec, what d'you think of the size? It doesn't just happen when playing games, when the PC is sitting idle with the desktop showing, it can happen then.
I've got a black desktop background set at the moment, so I can spot the problem when it comes back. No sign of it at the moment.
02 Jan 2012   #13
DeniqueCoelum
Quote   Quote: Originally Posted by seekermeister View Post
Okay, I'll give that a go and report back!
22 Jan 2012   #14
DeniqueCoelum
Okay, here's the latest. The problem went away for a wee whiley, but then it came back. I think I might've got to the bottom of it, however! I was having trouble with my audio (that's another story, involving a 5-speaker surround sound system plugged into one audio socket via a splitter), and I was fiddling about at the back of the PC, then my monitor cable popped out. I had trouble getting it back in again. Then I discovered that the adaptor (SVGA /VGA Adaptor 15 Pin Female to 9 Pin Female - my video card only has the VGA socket) had a bent pin. So I straightened it out and plugged the monitor back in. That got me thinking: might the flicker be caused by a dodgy adaptor?
What d'you guys think? Thanks for all your help so far, by the way!
screen constant flicker when playing games
Hi guy I need some help .... 2 days ago my games started flickering constantly in full screen mode only way to stop it is by playing in windows mode . But games don't look as good. I have an alienware m18x R2 2yrs old I 2.8ghz processer 2x GTX 680M graphic cards 16gig of ram. And windows 7...
Performance & Maintenance
Intermittent screen flicker when laptop connects to external monitor
I have a Dell Latitude E6410 running Win 7 Professional (64-bit). I have it connected to an external monitor. Whether I choose "projector" or the option to show on both screens, the monitor on the laptop will flicker. Here's more specific information that may be helpful: The laptop and a...
General Discussion
Monitor flicker + black screen on startup
Hey guys, just got a problem recently with my LCD monitor. It's a fairly old one (Acer 17"inch) and I'm suspecting that it's simply dying on me. The problem is that whenever I power on my monitor, the screen flickers on for a second and then immediately off. Probably something with the...
Hardware & Devices
Constant horizontal stripe along bottom of monitor picture
I don't know if this is hardware or software related, so I kept it in this topic. There is a constant horizontal stripe that takes up the second and third row of pixels from the bottom of my monitor. The color varies, but it seems to be some sort of an average color of the column above it. For...
General Discussion
Strange Startup - Monitor
The Compaq laptop with windows 7 starts up with a black screen, as soon as I start it up it will start the cooling fan but the screen does nothing but just a black screen. Before this happend, I was playing minecraft and then left it and when I came back the computer had automaticly locked, I tried...
General Discussion
Vizio 19" VA19L Monitor Screen Flicker During Video Games
Hi everyone, So I just got this brand new 19" BEAUTIFUL Vizio 19" HDTV Monitor from my Brother. He's a Coastie and can't bring it with him to A School, so he gave it to me as a VERY early Birthday and Christmas Present. I was, of course, VERY appreciative LOL. Anyway, the Monitor works great...
Media Center
