Strange constant flicker on LCD Monitor - help?!
DeniqueCoelum
7:32 AM
Falkirk, Scotland
I've been having this problem for a while now, and I really want to get to the bottom of it.
The flicker takes the form of narrow vertical shadows moving across the screen horizontally. It isn't particularly noticeable on lighter backgrounds, but on a darker screen, it's really distracting. I notice it most when play Minecraft (in dark areas) and at darker scenes during DVD playback.
I thought it might be that the monitor isn't getting enough power - there's my PC, an external HDD, surround sound speaker system and two lamps running off the same power supply - but I plugged it into a different supply, and still had the same problem.
One thing which might be causing it: the cable the monitor was supplied with is a European two-pin, rather than a UK three-pin, and I'm having to use an adaptor.
Any advice would be much appreciated!
Windows 7 Professional x64 SP 1Intel Core i5 - 3.2 GHz - Dual Core4 GBAsus Radeon HD 6770 1 GB
Fujitsu P9900 0-Watt
D2912 - μBTX
Realtek ALC663
Fujitsu SL 3230T 23" LCD TFT
500 GB Seagate / 500 GB Western Digital external HDD.
Corsair CX500
Fujitsu KB400 PS/2
Fujitsu OPT FSC BC
54 Kb/ps
Windows Experience Index Score: 5.9 |
Processor: 7.1 |
Memory: 5.9 |
Graphics: 7.3 |
Gaming Graphics 7.3 |
Primary Hard Disk: 5.9
If you are up to it, I would take apart the LCD and check the capacitors, you may just find a leaking or bulging capacitor which can be easily replaced, if you are into soldering.
Windows 7 Pro x64AMD FX 4100 4 Core 3.6GHz AM3+16GB G.Skill RipjawsXRadeon 6850
Home build
Windows 7 Pro x64
ASROCK 970 Extreme3
Radeon 6850
ASUS Xonar D1
ASUS 23" LCD
SSD 120GB
WD 750GB Black series
WD 640GB Black series
700W
Antec 100
Hyper 212 Plus
50MB
I'm afraid I'm not much of a soldering hand! Do you think that's what it's likely to be? I'm sure the monitor is still under warranty, it's less than a year old.
D2912 - μBTX
Realtek ALC663
Corsair CX500
Fujitsu KB400 PS/2
Fujitsu OPT FSC BC
54 Kb/ps
Processor: 7.1 |
Memory: 5.9 |
Graphics: 7.3 |
I'd be tempted to first check the refresh rate and resolution are set properly, in case it's not a hardware fault.
Might be helpful if we knew what screen it is since your spec's list two models... ;)
W7 x64Intel Q9300 2.5Ghz Quad LGA775 (Would like Q9...4Gb OCZ Gold 1,333MhzPalit HD4850 O/C Sonic 512Mb DDR3, Dual DViD's
Custom built machine
W7 x64
Intel Q9300 2.5Ghz Quad LGA775 (Would like Q9650)
Gigabyte GA-EP45T-UD3R (F6 Bios)
Azalia to twin Samson 50w Studio Monitors
Twin Dell (E-IPS) U2311H 23.6" Screens
1920 x 1080 @ 60Hz
Crucial M4 SSD, archives on twin Western Digital Caviar Black WD2002FAEX, 2TB, 7200rpm HDD's, Samsung Ritemaster CD/DVD Burner...
OCZ 600w
Lian-Li PC8 acoustifoamed' aluminium tower
Scythe 140mm Zipang
Cherry PS/2 custom model
Lenovo USB laser "Thinkpad" Mouse
ADSL2+ @14Mbps downstream & Cat6 Gigabit Ethernet
NOD32
Opera
Silicon Dust HD Homerun Dual FTA (Ethernet) TV Tuners, Dray Tek Vigor 2850Vn router and 8x HP Gigabit Switch. Lian-Li CR26 Card Reader, Canon MF4430 iSensys laser printer/scanner.
I think Qdos has got the right idea there. To add to that, check the hardware accelerator in adobe. I just went through something similar and had to disable the hardware accelerator in adobe while watching youtube video but that was after I upgraded my GPU, that's when I started seeing the screen flicker. Worth checking.
Windows 7 Ultimate 64 bitAMD Phenom II X4 965 Black EditionGSkill 4 X 2 GB PC 8500XFX Radeon HD 6790 D
Custom built
Gigabyte GA-MA790X-DS4
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
You might give the video cables the 'wiggle test'. With everythign on wiggle the ends on the monitor and the PC to see if you have any reaction. If so wherever you get a reaction would be the culprit. i.e. monitor or GFX adapter.
If that checks out, try another monitor if possible or that one on a different PC.
The monitor may just be bad.
Windows 7 Ultimate X64 SP1
ASUS P8Z68-V PRO/GEN3
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
Norton Internet Security 2013
Okay! Checked refresh rate and resolution, that's okay. I've updated my spec so that it lists the model I'm talking about, the 23". :)
Hardware accelerator... now, I'm afraid you're going to have to give me some pointers on that one, I'm not sure how to check that? :huh:
I've done the old wiggle test, nothing showing up there. It's not flickering at the moment, as far as I can see, and wiggling doesn't change anything. I'll try and get it hooked up to my parent's PC at some point and see what happens there. :)
D2912 - μBTX
Realtek ALC663
Corsair CX500
Fujitsu KB400 PS/2
Fujitsu OPT FSC BC
54 Kb/ps
Processor: 7.1 |
Memory: 5.9 |
Graphics: 7.3 |
Do you see the issue on the monitors own internal On Screen Displays (OSD)? The menu for instance. If the monitors own menu displays correctly, then it is a video problem (source). It is unlikely to be bad caps, especially on a one year old monitor. The major cap problem was limited to an older production run (see Capacitor Plague).
In a television, a steady rate horizontal or vertical scrolling would point to a bad ground or video interference due to shielding issues. If you can connect the monitor to another PC, you can quickly determine if it is the monitor or the PC. I believe a horizontal scrolling would be less likely with a monitor failure.
A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
ANTEC Three Hundred Illusion
85 + Mbps
Vivaldi
Custom built
On board RealTek HD
1600 X 900
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Just a guess, but when you mentioned playing games, I immediately thought of the video card not being large enough.
WIN7 x64 Home Premium SP1Intel Core i5-2400 processor(6MB Cache, 3.1GHz)8 GB RAM
DELLXPS 8300
8 GB RAM
1.5TB C Drive
Is it possible for you to disconnect the PC from the monitor and attach something else (like a DVD player) that would send a video signal to the monitor to determine if the flicker continues? That way you could be sure if the problem is actually in the monitor, or the PC. Even if not, it would be interesting to know if the flicker appears on the black screen without a picture. You could also open the monitor settings so that an image would be on the screen.
W7x64 Pro, SuSe 12.1/** W7 x64 Pro, XP MCEPhenom II 1090T w/Noctua NH-D14 /**4400+ X2 w...2 x 2GB Patriot PGS34g1600LLKA/**4x1GB Corsai...EVGA GTX460 SC/**EVGA 8800GTS
DIY
Asus Xonar D2X/**Xonar D1
HAF922/**Antec 1040IIB
3.3Mbps
(** = 2nd rig)
A Guy
I'm not sure! I'll certainly check that. Weirdly (and also mildly annoyingly), I haven't noticed the problem occurring since I started this thread!
Thanks! I'll check that out when I next get the problem, see if it helps!
My video card details are on my spec, what d'you think of the size? It doesn't just happen when playing games, when the PC is sitting idle with the desktop showing, it can happen then.
I've got a black desktop background set at the moment, so I can spot the problem when it comes back. No sign of it at the moment.
D2912 - μBTX
Realtek ALC663
Corsair CX500
Fujitsu KB400 PS/2
Fujitsu OPT FSC BC
54 Kb/ps
Processor: 7.1 |
Memory: 5.9 |
Graphics: 7.3 |
Okay, I'll give that a go and report back! :)
D2912 - μBTX
Realtek ALC663
Corsair CX500
Fujitsu KB400 PS/2
Fujitsu OPT FSC BC
54 Kb/ps
Processor: 7.1 |
Memory: 5.9 |
Graphics: 7.3 |
Okay, here's the latest. The problem went away for a wee whiley, but then it came back. I think I might've got to the bottom of it, however! I was having trouble with my audio (that's another story, involving a 5-speaker surround sound system plugged into one audio socket via a splitter), and I was fiddling about at the back of the PC, then my monitor cable popped out. I had trouble getting it back in again. Then I discovered that the adaptor (SVGA /VGA Adaptor 15 Pin Female to 9 Pin Female - my video card only has the VGA socket) had a bent pin. So I straightened it out and plugged the monitor back in. That got me thinking: might the flicker be caused by a dodgy adaptor?
What d'you guys think? Thanks for all your help so far, by the way! :D
D2912 - μBTX
Realtek ALC663
Corsair CX500
Fujitsu KB400 PS/2
Fujitsu OPT FSC BC
54 Kb/ps
Processor: 7.1 |
Memory: 5.9 |
Graphics: 7.3 |
