Solved Restart Cycle Problem on my newly built system.
altek
5:09 AM
Need some serious help someone, anyone! I am freaking out over here.
I put together my new rig tonight:
CPU - Intel Core i5-2500K
MOBO - MSI P67A-G43 (B3)
Memory - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
Hard Drive - Crucial M4 CT064M4SSD2 2.5" 64GB SATA III (SSD)
Power Supply - SeaSonic S12II 520 Bronze 520W ATX12V
Case - Thermaltake V4 Black Edition Gaming Chassis Mid Tower Steel
GPU – EVGA 02G-P3-1568-KR GeForce GTX 560 Ti (Fermi) 2GB
CD-ROM/DVD-RW - ASUS 24X DVD Burner
Mounted the mobo, installed the CPU and fan, made all the necessary mobo connections, installed the PSU, installed the video card, SSD drive and CD/DVD rom drive. Installed RAM. Made all the necessary power connections and double and triple checked everything. Built it just like I built my last rig. So I go to fire it up so I can get Win 7 on this bad boy and I am having some type of problem. I power up the PSU and hit the power button and the LEDs light up, fan starts up and it seems the computer is starting.. then about 2-3 seconds later it shuts off and turns back on and repeats this over and over until I manually shut the power. In that 2-3 second window, I tried opening the ROM drive and it works. It just seems like the computer is stuck in a restart cycle. It won't start up, just turns on and keeps restarting endlessly.
A few things to note is the hard drive is 2.5 and I don't have a 2.5 bay, but am getting a 3.5 mount for it Monday ASAP but I don't think that is the issue to be honest. It's flat and stable. Also, this SSD drive is going to be used to install Win 7 on and used just for an OS. I have other HD's with all my media and etc on. I am new to SSD's and also the whole SATA 3.0/6.0 thing.
Any suggestions as to what is wrong? I can't figure it out and I am going crazy losing my mind.
MS Windows 7 Professional 64-bit SP1Intel Core i5-2500KG.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin ...EVGA 02G-P3-1568-KR 2047MB GeForce GTX 560 Ti...
Custom build desktop
Intel Core i5-2500K
MSI P67A-G43 (B3)
EVGA 02G-P3-1568-KR 2047MB GeForce GTX 560 Ti (Fermi) 2GB
NVIDIA High Definition Audio
LG TV (1920x1080@60Hz) Acer H233H (1920x1080@60Hz)
Resolution 1920 x 1080 x 59 hertz
Seagate Desktop USB Device 1 Terabyte
Logitech USB Keyboard
Microsoft USB IntelliMouse Explorer 3.0
Optical Drives
DTSOFT Virtual CdRom Device
ASUS DRW-24B1ST a ATA Device
My first suggestion is to alternate ram , better yet it's best to have a minimal amount in there regardless for installing windows, it just tends to go more smoothly that way.
You can also try starting it without any ram in it at all.
If the motherboard is working properly it should beep, or at least alter it's behavior in some way being started with no ram in it.
Windows 7 x64Intel i7 2600kG.skill Ripjaw 16gigs @ 1866Nvidia gtx580 (evga)
Insane hobo technologies. ;-)
Windows 7 x64
Intel i7 2600k
Asrock z68 extreme 4 gen 3
Integrated HD audio + hdmi
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA)
Zalmann
Microsoft wireless 3000 (v2)
Yep. I found out it was a RAM issue. PC starts up fine now. Now I just have to install Win 7.
Intel Core i5-2500K
MSI P67A-G43 (B3)
Optical Drives
yeah behavior like that is 90% of the time a ram issue, and about 10% of the time a bad motherboard.
Glad you are sorted :)
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
