I'm sure you could relatively easily mount a slim 80~92mm fan to the case side, and use artic epoxy to glue on a heatsink to the CPU, and if you used the positive rails to rig that to 7 volts instead of 12 then you'd have a very much quieter solution - but I'd say you'd need to punch the case out for a grill in order to do that... but it'd make things a lot quieter :)
