Windows 7 Forums Search
Windows 7 - I have a 120HZ monitor, need help with the correct cable
02-09-2012   #1
Win7 Ultimate x64
So I first bought a HDMI cable (TV not working with HDMI cable).
Apparently the HDMI cable doesn't support more than 60HZ, so I googled around and apparently I need a dual DVI cable to support the 120HZ I can reach.
Now can I see, the difference between 60HZ and 120HZ? And can I dual monitor with one 120HZ monitor and the second one being 60HZ
Thanks for your help
 I have a 120HZ monitor, need help with the correct cable problems?
Similar Threads for: I have a 120HZ monitor, need help with the correct cable
LG E2750 Monitor and HDMI cable Graphic Cards
120hz monitor 4way splitscreen error Hardware & Devices
Is DVI better then the normal monitor cable? Graphic Cards
DVD I PC to Monitor Cable Question Graphic Cards
LF Flatron monitor cable ports Hardware & Devices
