a few months back my computer was working fine but one day it suddenly rebooted with a disk boot failure message.
when this happened both my OS drive and my data drive were not found by bios.
so both appeared to fail at the same time.
when i tested the drives on another person's PC both drives were found by BIOS no problems and my OS drive even booted and shutdown fine.
i narrowed it down to 4 possibilities from my knowledge
so i am thinking the SATA controller/ports is the issue and i am thinking about getting a new motherboard but i want to make sure that i am not missing some else.
also my IDE dvd drives seem to work fine just the SATA is the problem.
does any one have any advice or feedback on this issue such as other potential problem sources i didn't think of etc.
all feedback appreciated.
- bad SATA cables
- bad power supply
- bad SATA controller/ports
- the drives being detected on the second PC was a total fluke and the drives are bad
Windows 7 Home Premium 64-bitAMD Athlon X2 3800+ Dual Core @ 2.00 GHz Toledo4x1GB Dual Channel DDR PC3200Gigabyte GV R435OC-512I Radeon HD 4350
- Windows 7 Home Premium 64-bit
- AMD Athlon X2 3800+ Dual Core @ 2.00 GHz Toledo
- Motherboard
- ASUS A8R32-MVP Deluxe
- 4x1GB Dual Channel DDR PC3200
- Graphics Card(s)
- Gigabyte GV R435OC-512I Radeon HD 4350
- Sound Card
- Realtek HD Audio
- Monitor(s) Displays
- HP vs17 LCD VIZIO 32" LCD HDTV
- Screen Resolution
- 1280x1024+1920x1080
- Hard Drives
- Hitachi Deskstar 250GB
Seagate Barracuda 1TB 7200RPM
Seagate 3TB External Drive
- PSU
- 550W
