USB flash drive not detected...pls help!!!
ivan1717
9:13 AM
guys..my USB stick is apacer handy steno 256mb (old model) not detected when i plugged in..drive not appear in My Computer..taskbar never show the safety remove hardware..device manager show "USB Device"..when i go to Disk Management, it ask me to initialize disk, MBR or GPT, and a message pop up "device is not ready"..same message appear when i choose offline..i have gone thru many many forums but nth help...please advice me..those datas in that usb stick is important to me...:cry:
windows 7 32 bit
windows 7 32 bit
Might be the USB stick or something. Maybe it stopped working. Have you tried using it on other PC's?
Windows 7 Ultimate 32-BitIntel(R) Core(TM) i7 CPU 920 @ 2.67GHzCorsair DDR3 4GbNvidia Ge-Force GTS250
Gigabyte Technology Co., Ltd. EX58-UD3R
Corsair DDR3 4Gb
High Definition Audio Device
Envision 19 inch
1280x1024
2 physical hard drives (4 letter drives) that equal up to 626.3 gigs of space all together. I think both are Maxtors, but primary is a SATA drive, secondary is a SATA, too.
"Elite" style case
"Cooler Master"
Microsoft Optical USB Mouse.
Verizon DSL Internet
tried on another laptop using XP...still same...usb stick problem??:confused:
windows 7 32 bit
windows 7 32 bit
Sorry I haven't responded sooner.
The USB stick might be not working anymore.
You might be able to ask some people at a PC shop or something, but they'll probably ask for $$ even just to do a diagnostics or something.
Corsair DDR3 4Gb
Envision 19 inch
1280x1024
"Elite" style case
"Cooler Master"
It's really hard to diagnose what the problem is without being able to physically access the drive and find hardware problems.
You would probably need a flash drive data recovery company that specializes in recovering data off of usb flash drives..
like http://fixmyflashdrive.com
