need help setting up a "generic usb joystick"
so i bought a Tomee Wired Controller Wired TOMEE Controller for PS3 PLAYSTATION 3 USB NEW | eBay and the description says that i simply have to plug it in and the software will install by itself. the first time i plugged it it it said installing driver generic usb joystick so i assumed it worked.
im running windows 7 64 bit home premium btw
i tried this controller out of lots of games and after plugging it in the buttons did nothing. i was wondering if there was a special program that i can use? motioninjoy does not support this controller cause its not sixaxis controller, but i dont need it for the ps3, just my pc. when you go into properties and stuff you find a place that shows you what buttons youre pressing on the controller, so i know the computer is recieving the controlls, so i was wondering if there was a program that can translate those botton presses into say, left down up and right, or az,sx,dc etc.
if not, is there any way fo rmy games to work on this controller? remember this controller is not for ps3 but for pc so theres no worries that i need to translate ps3 code to pc code (idk if there even IS such a thing but whatever) thanks
