hard drive error
  1. Posts : 52
    home premium 64 bit
    hard drive error
    when I got my latest computer I partitioned the OS drive into 2 partitions and used the logical drive to store data. I now am having problems with it. When I try to open this drive I get 'M:\ is not accessible. Parameter is incorrect'. The drive is showing a healthy logical drive in My Computer but is inaccessible. Any help appreciated
  2. Posts : 12,012
    Post a screen shot of Windows Disk Management.
    What is the result if you go to a command prompt, change to the M drive, and enter this command:
    dir /s *.*
    Do you see a bunch of files flash by, and when it stops, do you see a numerical total of some kind?
  3. Posts : 52
    home premium 64 bit
    dir /s *.*
    when I try that I just get a 'invalid switch' message
  4. Posts : 12,012
    dir /s *.*
    With a space after the dir and after the s, but nowhere else?
    Or just try dir *.*
    A screenshot might help.
  5. Posts : 52
    home premium 64 bit
    ignatzatsonic said:
    dir /s *.*
    Or just try dir *.*
    no matter which way I try that from the command prompt I get 'invalid switch'
    here is a screen shot. the problem drive is M
  6. Posts : 12,012
    Uh-oh. That pic shows it as a RAW drive.
    I assume you have data on it?
    It sounds like a partition table error. Did you previously format M with the NTFS file system? And then put data on it?
    It's probably correctable with the right tool.
    You might get some ideas here:
    RAW Drive
    Or hope that SIW2 sees this thread.
  7. Posts : 52
    home premium 64 bit
    running testdisk now...could take awhile
  8. Posts : 11,269
    Windows 7 Home Premium 64 Bit
    Sometimes running a Disk Check on the drive with both boxes checked will fix the RAW error, as well. This is the easier solution if it works.
  9. Posts : 52
    home premium 64 bit
    I will give disk-check a try after testdisk has finished running. thanks for the info
  10. Posts : 11,269
    What is the current status of the system and the partition that was marked RAW? Any change?
