Battery Replacement Toshiba OEM or Battery-Biz
goldfrobe
12:49 PM
Ohio
I have to replace the battery on a toshiba L355-S7915 laptop. Which battery is better? The Toshiba battery or the B-5040H from battery-biz. anyone use battery biz?
Windows 7 x64, Ubuntu 11.04, Ubuntu 10.10Intel 2.20 Celeron 64bit3gb DDR2 6400Intel GMA 4500M
Toshiba
OEM
3gb DDR2 6400
Intel GMA 4500M
RealTek
19" LCD
Hitachi Travelstar
Ultra Pro Series 550watt (Desktop)
Ultra X Blaster (Desktop)
Active
Logitech USB
Logitech USB
This is just one of 2.
Could you provide links?
I think with batteries the big thing is Watt/Hours. (Don't quote me on that tho)
You might be better off using the same battery as the one you had before, simply for the sake of reliability.
It also will depend on what you use this laptop for.
Windows 7 Ultimate x64Intel i7 1st gen4gb ddr3AMD Radeon 5650
Dell Studio 17
Intel i7 1st gen
Studio 17
4gb ddr3
AMD Radeon 5650
some JBL thing
flippin' gigantic thing
scorpio blue - 200 gb
minifridge racks
a minifridge
homemade cardboard thing
i use a cat
not fast enough
whats left of a Studio 17, stuck into my fridge. not kidding.
Laptop Battery for Toshiba Satellite P200 P205 PA3537 at TigerDirect.com <-the Battery-Biz
Toshiba Primary 9-Cell Li-Ion Laptop Battery <-The Toshiba Brand
I am more curious if it is safe to use a brand like battery biz or if its about the same as using the OEM brand. In the end its a $50 price diffrence.
Toshiba
OEM
3gb DDR2 6400
Intel GMA 4500M
RealTek
19" LCD
Hitachi Travelstar
Active
Logitech USB
Logitech USB
I would go for OEM Toshiba battery but thats just me.I don't usually trust batteries for laptop from unknown manufacturers.
Windows 8 Prointel i3 2.40 Ghz6 GB RAMIntegrated Intel HD
DELL
Windows 8 Pro
intel i3 2.40 Ghz
DELL inc
6 GB RAM
Integrated Intel HD
Realtek high definition SRS surround sound
1366*768
320 GB
1Mbps
The no-name batteries most often die rather quickly, putting you right back in the same boat. If it was me, I'd spend more and get the OEM battery, knowing I had the backing of the real OEM behind it.
Intel Core i7-2600
Gigabyte GA-P67A-UD3P-B3
Nvidia GTX 470
Dell UltraSharp 2209WA
OCZ ModStream 700W
CoolerMaster HAF 912 Advanced
CoolerMaster Hyper 212 Plus
:ditto:
DELL
Windows 8 Pro
intel i3 2.40 Ghz
DELL inc
6 GB RAM
Integrated Intel HD
1366*768
320 GB
1Mbps
