intelguy77
- Local time
- 3:46 PM
- Messages
- 12
Need help finding parts and case for computer I'm building
Here are the parts I am working with (parts I bought and will be using in my new PC).
Graphics card (EVGA GeForce 9800 GTX+) -
http://www.newegg.co...N82E16814130339
Memory (OCZ 4GB (2 x 2GB) DDR2 SDRAM) -
http://www.newegg.co...N82E16820227248
Power supply (Ultra LSP750 750 Watts) -
http://www.tigerdire...p?EdpNo=3276567
(Let me know if this power supply won't work with the setup I'm looking for)
CPU (Intel Core 2 Quad) -
http://www.newegg.co...N82E16819115027
(I'm thinking of upgrading to an Intel Core i7. Let me know if this is an issue)
Also, I am using these speakers: http://www.sweetwate...re/detail/HS50M
The connection from the speakers are 1/4" cables, and they run to an interface, then that interface runs to my computer via USB. I wasn't sure if this is the best setup for using these speakers with a computer, or if I could find a sound card that would support them? Please let me know.
I need help finding a motherboard, an outer case, and anything else you could recommend. I'm thinking of buying a solid state HDD, let me know your opinion on them. Thanks for any help given!
Windows XP 32bit
- Windows XP 32bit
