How do I confirm that my CPU cooler speed is variable ?
  1. NRT
    Windows 7 Ultimate 64-bit SP1
    I have re-seated my CPU stock cooler because of over dust particles in my room.. Applied thermal paste... and connected to the four pins slot in the motherboard... Now I want to confirm my CPU cooler is running at variable speed. A simple doubt started in my mind is that, whether I connected the cooler's pin to the motherboard correctly (as its both sides were same) also want to clarify that I connected right ... plz help...
    Room temp: 34 C
    CPU temp: 35 C
  2. Posts : 1,360
    win7 ultimate / virtual box
    download and run CPUID, HWMonitor. then watch the fan speed as you stress your system
  3. NRT
    dowloaded and installed... thn how do I check ? by looking FANIN0 ?
    Attached Thumbnails Attached Thumbnails How do I confirm that my CPU cooler speed is variable ?-capture.jpg
  4. Posts : 525
    windows 7 home premium 64 bit
  5. Posts : 51
    Room temp: 34 C
    CPU temp: 35 C
    Hi
    On the MB near the processor the pins will say CPU thats the one to plug it into.Also go in bios to adjust the settings there , but from your cpu temps (cpu 35c) it looks like you are good to go.Remember the temp will not get cooler than the air temp in room.
  6. NRT
    I stressed my CPU by opening a program... now the fan speed varies to 2385 to 2545 ... and CPU temp from 34 C to 39 C ... so my fan speed is variable... Am i right ?
  7. NRT
    anybody plz confirm my previous question...
  8. Posts : 1,360
    yes
  9. Posts : 13,576
    Your BIOS will give you the best reading. There are also settings you can use to change the speed.
  10. Posts : 568
    Win7 x64 Ultimate SP1
    Those temps are low so it's still on idle. need to get to above 50C or so to speed up the fan on most standard Bios settings.
    Ken
