How do I confirm that my CPU cooler speed is variable ?
NRT
Power User
8:33 AM
Kerala, India
I have re-seated my CPU stock cooler because of over dust particles in my room.. Applied thermal paste... and connected to the four pins slot in the motherboard... Now I want to confirm my CPU cooler is running at variable speed. A simple doubt started in my mind is that, whether I connected the cooler's pin to the motherboard correctly (as its both sides were same) also want to clarify that I connected right ... plz help...
Room temp: 34 C
CPU temp: 35 C
Windows 7 Ultimate 64-bit SP1AMD Athlon II X2 260 @ 3.2 GhzKingston 8.0GB Dual-Channel DDR3 @ 669MHz (9-...ASUS EAH 5450 - 1 GB
Assembled
Gigabyte Technology Co., Ltd. M68MT-S2 (Socket M2)
Kingston 8.0GB Dual-Channel DDR3 @ 669MHz (9-9-9-24)
23 Inch - DELL SP2309W
2048 x 1152
488GB Seagate ST3500418AS ATA Device (SATA)
450W
Iball - Standard Form - i8190
Stock Cooling
1 MB/Sec
Creative Inspire 2.1 Speakers, LITEON 24x DVD Writer
win7 ultimate / virtual boxIntel Core i7 3770K,1155, Ivy BridgeGSkill Ripjaws Z Series 1600 CL 9.0 16GBKFA2 GeForce GTX 670 EX OC 2048MB GDDR5 PCI-E...
built my own
MSI Z77A-G43
KFA2 GeForce GTX 670 EX OC 2048MB GDDR5 PCI-E gfx card
onboard Nvidia HDMI audio
ASUS VK222H 22" widescreen LCD monitor
Kingston 128gb SSD
OCZ Vertex 90gb SSD
500GB WDCaviar 16mb 5000KS
320GB WDCaviar 16mb 3200AAKS sata 2
1TB Samsung 16mb HD103SJ sata 2
Corsair HX 750W ATX2.2 Modular
Antec 25 Kuhler H2O 620
logitech
logitech MX518
7mb adsl
  • Like
Reactions: NRT
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
windows 7 home premium 64 bitAMD Phenom(tm) II X4 830 Processor, 2800 Mhz,...12.00 GBATI Radeon 4200
HP/ Pavilion P6751C
AMD Phenom(tm) II X4 830 Processor, 2800 Mhz, 4 core
N-Alvorix-RS880-uATX (Alvorix) motherboard
12.00 GB
ATI Radeon 4200
Creative Labs Sound Blaster Recon3D
46" Sony TV KDL-46NX810
1920x1090P
1 TB
Internal 250W
Mid-size ATX
1 rear case fan
Logitech USB Wireless K800
Logitech USB Wireless M305
22mb-28mb
  • Like
Reactions: NRT
Room temp: 34 C
CPU temp: 35 C
Hi
On the MB near the processor the pins will say CPU thats the one to plug it into.Also go in bios to adjust the settings there , but from your cpu temps (cpu 35c) it looks like you are good to go.Remember the temp will not get cooler than the air temp in room.
Windows 7 Ultimate x64i7 2600k8G Corsair-DDR3GTX 260 Evga
Samurai Jack Special
i7 2600k
Asus-P67-Sabertooth
8G Corsair-DDR3
GTX 260 Evga
HP 2711x
3 Samsung.. 500G/250/250/
Corsair
Antec
5 Fans
Laptop Asus G75VW. A little heavy but its a Beast...
  • Like
Reactions: NRT
I stressed my CPU by opening a program... now the fan speed varies to 2385 to 2545 ... and CPU temp from 34 C to 39 C ... so my fan speed is variable... Am i right ?
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
anybody plz confirm my previous question... :zip:
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
yes :cool:
built my own
MSI Z77A-G43
Kingston 128gb SSD
OCZ Vertex 90gb SSD
logitech
logitech MX518
7mb adsl
Your BIOS will give you the best reading. There are also settings you can use to change the speed.
Skylake Special #666
Intel Core i7 6700K
Asus Sabertooth Z170 Mark 1
EVGA GTX 980 Ti SC x2
Realtek High Definition
AOC G2460PG
Logitech G910 Orion Spectrum
Those temps are low so it's still on idle. need to get to above 50C or so to speed up the fan on most standard Bios settings.
Ken
Win7 x64 Ultimate SP1Intel i7-26008 GigGeforce gt 520
Dell Optiplex 980
Intel i7-2600
8 Gig
Geforce gt 520
LG & Acer
Fios 45/35
Windows Home Server
Ken
Thank u all for replying.... :)
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
Ken
I'm currently encoding a movie. My CPU is running at 59C. CPU fan 1921 RPM. Case fan 1982. Ambient 42C
HP/ Pavilion P6751C
12.00 GB
ATI Radeon 4200
1920x1090P
1 TB
Internal 250W
Mid-size ATX
1 rear case fan
22mb-28mb
Thank u for the info Quickdraw2011... :)
Assembled
2048 x 1152
450W
Stock Cooling
1 MB/Sec
HWMonitor will list min and max CPU fan speed.
A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
ANTEC Three Hundred Illusion
85 + Mbps
Vivaldi
  • Like
Reactions: NRT
HP/ Pavilion P6751C
12.00 GB
ATI Radeon 4200
1920x1090P
1 TB
Internal 250W
Mid-size ATX
1 rear case fan
22mb-28mb
A Guy
The utility Fanspeed shows min and max by hovering the curser over fans. I believe it's an older utility and not as detailed as HWMonitor.
HP/ Pavilion P6751C
12.00 GB
ATI Radeon 4200
1920x1090P
1 TB
Internal 250W
Mid-size ATX
1 rear case fan
22mb-28mb
You can go to BIOS or dowload speedfan to monitor the fan speed of the cooler actually. Then you can play around with the setting to see if the fan is moving up and down.
Windows 7 32 bit
Windows 7 32 bit
Ken
Forgot to mention, the rig I'm using to encode a movie is an old XP machine, with single core processor. Pentium 4 Prescott Core (P4). They run hot!
Check out this article.
Testing Thermal Throttling in Pentium 4 CPUs with Northwood and Prescott cores
HP/ Pavilion P6751C
12.00 GB
ATI Radeon 4200
1920x1090P
1 TB
Internal 250W
Mid-size ATX
1 rear case fan
22mb-28mb
