Help with a strange problem, Computer running super slow
wself
4:38 PM
Ok guys first time here so thanks for reading.
Ok here goes my problem, first off my power supply went out. It was a 450watt one I ordered and replaced it with a 750watt power supply.
After i replaced the power supply, my computer would not boot, When the power supply went out it was in the middle of updating windows. So I formated the hard drive and did a clean install of windows, reloaded all my drivers and extra programs. At that point my computer was running great.
I decieded to uninstall Bing tool bar, and windows live sign in assisant. it prompted my to reboot. When i rebooted the computer, after about 30 minutes it still hads not come up to the desktop, I could boot up in safe mode and it would run fine. I did a system restore, no change, I did a start up repair, no change, Tested the memory it came back fine.
So i got mad at that point and reformated the hard drive again, I had another hard drive formated it and put the install CD in and after 8 hours it is still trying to install Windows 7, No errors just really really slow.
So at this point, i have replaced the power supply, hard drive, and ran a memory test with no errors, done a clean install of windows.
Running Windows 7 64 bit, 4 gig of Ram, 2.8 dual core processor, 1 gig video card, 500 gig hard drive.
Any help would be great. I am leaning towards the ram being bad.
Windows 7 Home 64 bit
Don't rule out a motherboard (or CPU) problem. Since the power supply died while running, anything is possible. If you suspect memory, remove all but one memory module and see if that makes a difference.
Also, reset the BIOS and see if that makes any difference.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Ok tried removing a stick of the ram and booting, No change tried each stick seperate. I also went back and reset the Bios back to default.
My computer
CyberpowerPC GX1220 Desktop Gaming PC - Intel Core i5 750 2.66Ghz, 4GB DDR3, 500GB SATA II HDD, Nvidia GT 220, DVDRW, 420W PSU, Windows 7 Home Premium 64-bit
is there some kind of test to figuer out if mother board the issue?
windows7 64bit
windows7 64bit
