Help regarding connecting Laptop TO Desktop using LAN CABLE
  1. Posts : 11
    Windows 7 64 Bit
    Hello friends I am new on this forum
    I just bought a laptop and I was trying to connect it to my desktop by using LAN CABLE for data transfer.
    I have tried everything my way but it is not working
    Control Panel\Network and Internet\Network Connections -> Local Area Connection -> Properties -> Internet Protocol Version 4 (TCP/IPv4) -> Properties
    I set my computer's ID to 192.168.1.2
    Subnet Mask : 255.255.255.0
    GateWay : 192.268.1.1
    I set my Laptop's ID to 192.168.1.2
    What more I need to do to connect them?
    Please help me as soon as possible.
    Thank you in advance.
  2. Posts : 28,845
    Win 8 Release candidate 8400
    If the cable isnt going through a router or switch it needs to be a "null" cable, also called a crossover. A regular cable wont work.
  3. Posts : 11
    Windows 7 64 Bit
    No sir I am connecting it directly to both the devices.:)
  4. Posts : 2,073
    Windows 10 Pro 64-Bit
    This should Help you. :)
  5. Posts : 352
    Windows 7 Home Premium 64-bit
    Please go with what zigzag has said and use a crossover cable and not a standard one and these are usually marked as such. The way to tell is look at the colours and placing of the wires into each end if they look the same it is not a crossover cable.
    Also, for peer to peer connection, IP adresses need to be different for them to "see" each other.
    Hope this helps.
  6. Posts : 11
    Windows 7 64 Bit
    Hope this helps.
    Sir I have tried it with my friends laptop and it worked finely with the same cable but I am missing some settings I think so
    Please guide me what more it needs to do :)
  7. Posts : 2,073
    you mentioned "same cable" which means the standard cable right? you should use what zigzag3143 suggested, a crossover cable would fix your problem.
    Please click HERE for step by step on how to make crossover cable
  8. Posts : 352
    For you to be able to transfer data from one PC to another the IP addresses must be different - if you have them as stated above, it will not work.
  9. Posts : 11
    Windows 7 64 Bit
    Oh thanks for pictorial answer but I am using Crossover Cable only
  10. Posts : 11
    Windows 7 64 Bit
    I am sorry I set laptop's IP to 192.168.1.3 :)
