Windows 7: Help regarding connecting Laptop TO Desktop using LAN CABLE
01 May 2012   #1
nkam
Windows 7 64 Bit
Hello friends I am new on this forum
I just bought a laptop and I was trying to connect it to my desktop by using LAN CABLE for data transfer.
I have tried everything my way but it is not working
Control Panel\Network and Internet\Network Connections -> Local Area Connection -> Properties -> Internet Protocol Version 4 (TCP/IPv4) -> Properties
I set my computer's ID to 192.168.1.2
Subnet Mask : 255.255.255.0
GateWay : 192.268.1.1
I set my Laptop's ID to 192.168.1.2
What more I need to do to connect them?
Please help me as soon as possible.
Thank you in advance.
01 May 2012   #2
zigzag3143
Win 8 Release candidate 8400
If the cable isnt going through a router or switch it needs to be a "null" cable, also called a crossover. A regular cable wont work.
01 May 2012   #3
nkam
Windows 7 64 Bit
Quote   Quote: Originally Posted by zigzag3143 View Post
No sir I am connecting it directly to both the devices.
01 May 2012   #4
sk0t0s
This should Help you.
01 May 2012   #5
ibshaw
Windows 7 Home Premium 64-bit
Please go with what zigzag has said and use a crossover cable and not a standard one and these are usually marked as such. The way to tell is look at the colours and placing of the wires into each end if they look the same it is not a crossover cable.
Also, for peer to peer connection, IP adresses need to be different for them to "see" each other.
Hope this helps.
01 May 2012   #6
nkam
Windows 7 64 Bit
Quote   Quote: Originally Posted by ibshaw View Post
Hope this helps.
Sir I have tried it with my friends laptop and it worked finely with the same cable but I am missing some settings I think so
Please guide me what more it needs to do
01 May 2012   #7
sk0t0s
Quote   Quote: Originally Posted by nkam View Post
you mentioned "same cable" which means the standard cable right? you should use what zigzag3143 suggested, a crossover cable would fix your problem.
Please click HERE for step by step on how to make crossover cable
01 May 2012   #8
ibshaw
For you to be able to transfer data from one PC to another the IP addresses must be different - if you have them as stated above, it will not work.
01 May 2012   #9
nkam
Windows 7 64 Bit
Quote   Quote: Originally Posted by timbog View Post
Oh thanks for pictorial answer but I am using Crossover Cable only
01 May 2012   #10
nkam
Windows 7 64 Bit
I am sorry I set laptop's IP to 192.168.1.3
Connecting HDMI cable to TV crashes laptop
Hi, When I connect the HDMI cable to the TV, I see nothing on the screen and my laptop starts to blink until it causes an error to the graphics card and sometimes the computer crashes, checked several HDMI cables and that's not the problem. Any suggestions what causes this? Thanks for the help.
Graphic Cards
Hello friends I am new on this forum I just bought a laptop and I was trying to connect it to my desktop by using LAN CABLE for data transfer. I have tried everything my way but it is not working :( I am using Windows7 ultimate and Windows7 Premium OS. Control Panel\Network and...
Network & Sharing
Resolution Issue when connecting Laptop to Monitor via HDMI cable
Hey everyone, I'm having this problem with Dota 2 and Diablo III. Whenever I connect my approximately 15" laptop to my 24" monitor using an HDMI cable, it forces me to use a lower resolution in order for the game to not be laggy. When I use my laptop by itself, it can support the highest resolution...
Graphic Cards
Connecting to Xbox Live using Ethernet Cable, Laptop & USB Dongle
Ok so I've been at this all day with no solution to my problem!! My set up is USB dongle(Huawei e173) in my laptop (connected to GiffGaff-which runs on o2 network) Xbox Connected to laptop via Ethernet Then I'm sharing the USB internet with the Ethernet using ICS. The problem I've having...
Network & Sharing
Connecting laptop to desktop
Hi, what is the best and simple way of connecting a laptop to a desktop directly? My requirement is that I need to transfer a data folder from a laptop to a desktop and then reinstall Win 7 on laptop. Thanks!
General Discussion
Connecting laptop to a desktop
My desktop have a big monitor and I'm able to connect my laptop to it but the problem is I would be using a lot of energy and stuff. Is there a way I can close the laptop or what ever and just use the desktop but with laptop turned on?
General Discussion
