I need help setting up a RAID system
  1. Posts : 7
    Windows 7 64-bit
    So I've had a NAS Server built for about 2 years now, all that it has in it at the moment is a 2TB data drive and a 20GB OS drive. But I want to take it to it's full potential now that my money situation is in check. I'm going to be buying 5 more 2TB HDD's and I want to RAID them together. My issue is that in all my years of working with computers, I've never once dealt with RAID before .
    This machine is running Windows Server 2008 R2 on a Mini ITX motherboard in a Lain Li Server case, with 6 3.5" HDD bays.
    Complete systems specs:
    CPU: AMD Phenom x4 @ 2.2ghz
    RAM: 4GB DDR2 @ 800mhz
    EVERYTHING ELSE: Onboard
    This is the exact motherboard that I have right now.
    Newegg.com - ZOTAC GF6100-E-E AM3 (up to 65 watt TDP) / AM2+ / AM2 NVIDIA nForce 430 MCP Mini ITX AMD Motherboard
    Now as you can see it only has 4 SATA ports. I need 8 in total, 1 for my 2.5" 20GB OS Drive, 6 for my 12TB of Data drives, and 1 for my Hot Swap bay. So what I was thinking is I could get this RAID card.
    Newegg.com - SYBA SY-PEX40013 PCI Express SATA RAID Controller Card
    Now what I'm trying to do exactly is RAID the 6 2TB HDD's together for a total storage of 12TB showing as 1 drive in Windows. I'm not concerned about performance because this is just streaming movies/shows to my WD TV Live that is sitting right next to the server, connect via gigabit network.
    But because I've never worked with RAID before, I don't know how to go about using 2 different controllers as one, would I do that in BIO's or with software, which RAID version would be the best and simplest for me to use? Please give me any details to make my purchase/setup as easy and as painless as possible. The only thing I'm not willing to do is buy a new motherboard/server setup. I didn't buy the RAID card yet, so if you have any other suggestions, please link them to me :)
    Thanks a lot in advanced :)
  2. Posts : 7
    Windows 7 64-bit
    And just for a little more added info, this is the hard drive I have, and I will be buying 5 more of these
    Newegg.com - Seagate Barracuda Green ST2000DL003 2TB 5900 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
  3. Posts : 31,250
    Not done a lot of raid set-up recently but I would suggest the best solution may be to ignore the motherboard SATA ports for the raid setup and use a discrete card instead - not sure of budget
    I would use the on-board SATA for the OS and hot-swap drives, and add an 8 or 12 port card to service the raid drives (allows for future expansion )
    One possibility is here ... Areca's 1100 Series ARC-1130ML 12-Port PCIx RAID Controller [Not a recommendation just the first suitable hit on a search]
      My Computers
  4. Posts : 7
    Windows 7 64-bit
    Ok, that's what I was thinking about doing, but I just didn't know if that was a good idea. The issue I'm facing now is finding a card that has 6 SATA slots, or at least a 2 SAS slots that can be split to SATA, I want to stay around $100 and it has to be PCI-e 1x. It's not a server board, it's just a basic Mini ITX PC motherboard.
    So if anyone knows of a PCI-e 1x RAID card with either 6 SATA II connectors or 2 SAS connectors that's has splitter cables with it.
