Windows 7: Up key not working, Brightness stuck on low settings (FN+UP)
05 May 2012   #1
Nurein615
Windows 7 Ultimate 32bit
I have a dell latitude d620 and one day the up and left keys magically stopped working.. later on I had the brightest idea to see whats the lowest level of brightness possible, now I'm pretty much screwed because I cannot get the brightness back up to normal (which is a pain in the rear end) using the FN+UP combination.
I've searched the web trying to find a solution and cannot find anything, any solutions?
Help is very appreciated
06 May 2012   #2
A Guy
Welcome to Seven Forums Nurein615. I think you can adjust it in BIOS with the down right keys (I hope they work!). Here is a (poorly made ) video that will illustrate how. Basically, F2 at boot, then video settings, then brightness. Don't go too bright as you have no left key to turn it back down! Good luck!
Dell D630 Lattitude Brightness Settings from The Bio's Menu. - YouTube
A Guy
Mobility 5850 - 3D games freezing, with brightness stuck
Since last Monday, my laptop's been through its fourth at Knowhow's facilities. I was anxious to play games like Euro Truck Simulator 2 and Gmod again, but after a minute or two of gameplay, they would both freeze. From there the screen would turn black, turn back on at full brightness, and allow...
Graphic Cards
Brightness slider not working at all
Hi, I was just reading things and suddenly my screen blacked out entirely. For whatever reason, I felt like I should shut down the computer and restart, and now my screen is permanently dimmed. I'm running Windows 7 Professional 64 bit on a toshiba laptop, if that helps. I've tried the power...
Hardware & Devices
On Windows 7 the brightness settings are reversed
The brightness settings under power options are reversed setting the brightness setting to the left brightens the screen and setting the gauge to the right makes the screen dimmer is there a way in the registry or possibly a program that can reverse this behaviour in windows 7?
Hardware & Devices
Screen brightness stuck after unplug during sleep
I'm having problems with adjusting my screen's brightness after I unplug my laptop while it's sleeping. The screen can't be adjusted from the hotkeys or by right clicking power options. Adjusting the brightness is no problem when I wake up the laptop from sleep and I haven't plugged or unplugged...
Drivers
Lenovo Brightness settings (FN keys)
hi, i have a lenovo ideapad y570 windows ultimate , its been 5 months of use and there is of course there is no prblem with it at all..but then i noticed when i press fn+up/down,normally it will adjust brightness of my laptop and it will display rectangular bars showing how bright my laptop...
General Discussion
Adjust Brightness brings up Power Plan settings!
I just noticed that in Display properties, the Adjust Brightness brings up the power plan settings....
General Discussion
