Windows 7: Power supply problems?
12 May 2012   #11
FaberTech
Windows 7 x64 / Windows Server 2008 / Linux (Redhat & Deb distros) / OS X / More
Just make sure the video card doesn't need extra six pin plugs. If it does, you should hook them up. Mine requires two six pin plugs. also, a lot of motherboards require the extra 4 -8 pin be hooked up near the processor. I have made the mistake of not hooking it up before. :/ Also, unless you live in Europe, make sure your Power Supply switch on the back is at 115V.
12 May 2012   #12
linnemeyerhere
Windows 7 Ultimate 64
Well I hope that the PSU isn't bad from the get go and also in a perfect world we would have directed you to a host of top quality brands which would outperform this unit with higher ratings and also have either a semi or total modular design which allows you to only use the connectors you need and no more. So lets hope the PSU is faulty and then you just have to RMA it. If they give you grief then try to work your money back and then hit us up so we can suggest quality options that you can carry forward to you next several builds.
12 May 2012   #13
Al Fairclough
I believe that Dell uses their own proprietary pin-out pattern for their PSU on that model. That being the case, you are stuck with a Dell PSU.
12 May 2012   #14
frogmaster
Well, I fixed the problem myself. Guess I just got lucky; I just plugged in everything, turned it on, and it worked.
12 May 2012   #15
Al Fairclough
Quote   Quote: Originally Posted by frogmaster View Post
Outstanding! Now, go buy a lottery ticket.
12 May 2012   #16
linnemeyerhere
YEAH! It's always something silly like you thought the connectors clicked but it wasn't fully seated. Good work, enjoy and post some pictures when you get a chance.
Bought new Power Supply Unit, won't power on. Did I buy the wrong one?
I have a Corsair CX430M PSU with 4 slots to connect in the back. CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com & bought a new Antec BP550 Plus PSU, which has 5 slots to connect to. Antec BP550 Plus ATX12V V2.2 80 PLUS Certified Modular...
PC Custom Builds and Overclocking
Power supply not enough?
Hello, I recently built a new computer and it has been running fine without any problems. Although, whenever I play games like BF4 or CSGO the exhaust fan at the back seems to slow down a bit and has a little bit of clicking. Is my power supply enough for these components? Gigabyte R9 290...
Hardware & Devices
Hardware Power Consumption-Picking a new Power Supply
Ok, so it's time again for me to pick a new power supply, however, I'm in need of some help determining the appropriate wattage for my hardware setup. AMD Phenom II X4 955 45nm AM3 GSkill Ripjaw X 16.0 GB Dual-Channel DDR3 @ 668MHz (9-9-9-24) Corsair TX750w (I dont think its the V2) ASUS...
Hardware & Devices
Power Supply
Hi, i have the HuntKey H301 case with its original power supply, when im playing a game it is starting to do a weird noises, can i do something with this?
power supply
hi guys today i went to turn on my pc. on the back of my tower bent of to switch on the power supply and when i switched it on i heard a big bang and then all the power power went off. i went outside and checked the fuses and one of the fuses was blown so im gguessing dose that mean i need a new...
Hardware & Devices
THE Best Power Supply?
The Power Supply is the heart of any computer system, after all, no matter how much you have invested in all those expensive cutting edge parts, they are dead if there is no power! But finding a good power supply is a daunting issue. This forum cannot scientifically test power supplies so I am...
Hardware & Devices
