Solved How to View 32bit Hard Drive on 64bit System?
crazykilla
12:21 AM
[Solved] How to View 32bit Hard Drive on 64bit System?
Hello This is CrazyKilla
I am here with another porblem,
I recently got a new custom pc, i have a 300Gb 32bit hard drive, stupid me forgot to save my files from the 32 bit hard drive, onto a usb, now i have a 64bit system, and a 64bit hard drive, i want to get my files back from the 32bit HD but i dont know how, if i try to use the 32bit HD it just gives me blue screen, right now im using 64 bit hard drive (130gb), help please!
Windows 7 Ultimate 64-bitIntel i7-3820 @ 3.60GHz24GB2xNvidea GTS 450 SLI
MSI X79A-GD45 8D
24GB
HP w2408h 24" monitor
1920x1200
2 Terrabyte 6GB/s HDD
Cooler Master 912 HAF
Intel Water Cooling for CPU, 6 Fans.
100MB/s
None - Like a Boss
leave your "64bit Hard Drive" plugged in to SATA port 1, plug your "32bit hard drive" into sata port 2. Reboot, go into BIOS, ensure that the primary boot device is set to your "64bit Hard Drive". Save and exit. Login to Windows, Windows Explorer, navigate to the "32bit Hard Drive" , open the folders you want to get files from and then drag them to a newly created folder in your "64bit Hard Drive". You WILL NOT be able to run programs that are on your "32bit Hard Drive". You will only be able to rescue files, such as documents, pictures, music, movies, etc. After you're done with the files on the "32bit Hard Drive", you should reformat it and use it for backups.
Windows 7 Home Premium x64Intel 2500k @4.5ghz 66deg max P95/IBT8 Gigs Patriot Viper 2 Extreme @1600EVGA GTX 580 3 GIG 35degrees idle
Home Made
Gigabyte Z68A-D3-B3
Nvidia HD audio via HDMI to 7.1 Receiver
32" Olevia hdtv
1080p
64gig SSD(OS/Apps)
250gig (Files and Dox)
1tb (imaging and backup)
Corsair vx550w
Thermaltake V3 black
CM 212+(push n pull) 4 case fans
Logitech wireless Combo, G13
G300
40mps
Two others up and running; C2D E5200/MSI G41M-P26/Corsair XMS3 8gb/GTS 250 1gb and C2D E8200/xFx 750sli/8gb Corsair Dominator/2x EVGA 550ti
Working on; i2600 Build...
HP DV6
@Work I use a Lenovo 5536B8U + Lenovo U300s
crazykilla,
Problem solved?
MS Windows 7 Ultimate SP1 64-bitAMD A10-4600M6.00 GB Dual-Channel DDR3 @ 798MHz (11-11-12-28)AMD Radeon HD 7660G
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
Yes my Problem is now solved, ill now change title to solved, the forums helped me alot!
MSI X79A-GD45 8D
24GB
1920x1200
100MB/s
None - Like a Boss
Old 32 bit hdd will not run on 64 bit laptop
I have some old files I need to transfer from a 32 bit win 7 hard drive to my 64 bit laptop. I've tried to remove the write protection but I do not get the recommended registry entries to alter. I do not wish to use this drive except to remove the old documents. I get an error "write protected" when I try to run the old drive from my hard drive enclosure. PLEASE HELP, important medical records are on this drive that I need desperately.
Thanks AFTommy
win7 home premIntel CORE i34 gig
Toshiba Satellite C655-S5212
win7 home prem
Intel CORE i3
4 gig
1366 x 768
12Mbps
Do you still have your pc? You could transfer files from pc to laptop using internet, but overall i dont knownhow to help, the only advise i acn give you is to make a new post because no one will look here becase it says [Solved] in the title
MSI X79A-GD45 8D
24GB
1920x1200
100MB/s
None - Like a Boss
