#21
I did a little shopping around for you, and found this. It goes in the back panel, and could be used to cool that GPU: http://mobile.maplin.co.uk/module.aspx?moduleno=29335
not sure if that could get in palce since my card is taller than the normal pci slot (those big heatsinks). Have to say that's a pretty nice idea though, keeping the airflow on the card instead of going past it! I had forgotten about the term "expansion slot", I was generally searching for PCI
I'm not so certain I have the same faith that case designers planned for all. I think some of the problem is being caused by the bi-directional exhaused on my graphics card ducts. Most of the cards these days only pump the air out the back and out of the case, but the inward stream seems to be playing games with my circulation. I don't want all my air bypassing my graphics card either. If I had been able to get my processor fan sideways I would have been better off too.
Now I've got that hint that non geeks still call them "expansion slots" i've found some interesting things.
Intake or outtake aside, this interests me: Vantec ? Vantec Spectrum Fan Card - SP-FC70-BL - System Fan Card with Dual 70mm Adjustable UV LED Fans . I do hate this "LED your life" culture though, why not just go lights of?
This could be the do all solution for dead spots: Amazon.com: Antec SpotCool System Cooler: Electronics I guess this gives me the most choice
If only I could get liquid cooling for VGA cards...
We are almost there.....
PNY Pushes Liquid Cooled Graphics Cards to the Masses - HotHardware
interesting that they are FINALLY getting there. Tubes look pretty short though, barely long enough to take the radiator out of the box (always wondered, just where are you going to stick it? need a water cooling case with a 20x45cm heatsink gently lining the tower roof with a couple of 200mm fans on it, then we are talking)
Of course, it's still a little close to the basic design, just make the cards double sided and heatsink both sides instead of focused on one hot side?
Part of my concern is the old technology still used by ATI. I'm increasingly feeling they've been left standing for a couple of years, and will probably take an Nvidia card next time around for the improved performance vs power. That my card is rates as 350W really does say it all: I don't think I'll ever get a rig that will make is possible to comfortably run that at full pelt, yet slowly games are coming out that finally are pushing the card (no complaint about the performance mind). Still, I'll wait for a general all scale upgrade until Intel get their act together on the scaling of their Ivy Bridge processors for desktops. I'm also interested in the hybrid SLI concept, since undoubtedly CPUs have more space and better positioning for cooling than any graphics card.
No one in their right mind would want to pour water on a hard drive, lol. That aside, as I was saying... the rear exhaust fan would help. As for the bigger heatsinks/fans for the cpu, it doesn't really put stress on the motherboard if it's mounted properly. Meaning the motherboard and the heatsink. They wouldn't build big bulky heatsinks if the motherboard couldn't handle it. If that were the case, then these new huge graphics cards would be a bad idea as well. I didn't need all 6 fans I put into my computer, but I wanted to be sure to use the true design of the case and get good airflow. I don't overclock, but I could on air. My processor doesn't go over 40-45 on full load, and that's just off of air.
I'm not sure what case you have, so I'm not sure how many fans you can mount in your case. I do notice the top and rear exhaust, but I don't see any others from the pictures. Putting a fan on the back can help from heating up by exhausting more of the hot air. A new cpu cooler could also help by pushing that warmer air out of the exhaust quicker as well if it gets close to it.
Keep in mind, I'm just suggesting ideas and you can do as you will with them. I've never used a pci cooler, so I'm not sure how well they work.
Hopefully you can figure out a solution soon.
LOL, no, it was assembled on my desk to test it before committing to a case since I have had so much trouble with dead ASRock boards.
The cooler I mentioned has a large backplate and is supported very well with no distortion. An added benefit is that some air bleeds out of the fins on the side onto the back side of my GPU card.
the big sinks still terrify me. remember the force on the boards is multiplied by the height of the heatsink. GFX cards are insane, but at least the back slot screw transfers a large portion of the cantilever into the chassis.
That said, that's a new, £15 heatsink on the psu and even hammering it with everything i have i can't get core 0 past 43C or cores 1-3 past 41C. I really have no problems with CPU or exhaust, only with getting air to my GPU
