Windows 7: Hardware Power Consumption-Picking a new Power Supply
17 May 2012   #11
ignatzatsonic
Quote   Quote: Originally Posted by abyoung35 View Post
awesome thanks guys, so i need to pat attn to the amp rating per 12V rail? so theoretically if i could find a psu with 2 12v rails at 35 amp ea. @ 840w total, that would be a good one? (based solely on numbers
No.
A "good one" is a PSU with adequate power for your particular requirements, from a reliable manufacturer.
You can all finds of lousy PSUs that have good specifications on the label. The specs for those PSUs mean very little because you don't know if the specs are true. And even if "true", under what circumstances were they measured? 840 watts for 10 seconds, then fails? 840 watts in a highly refrigerated room?
And you need to pay attention to TOTAL power. A PSU that has two 12 volt rails at 35 amps each may be able to supply only 700 watts total at any time.
Check reviews and comments at jonnyguru.com.
23 May 2012   #12
abyoung35
i purchased the corsair h60 and my cpu temp has not gone over 53C, I've had less crashes, but a few still linger around. I've chosen the Seasonic X750 Gold, its at least 100 w over my required. I'm ordering it next monday
Newegg.com - SeaSonic X750 Gold 750W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
23 May 2012   #13
Phone Man
Its on sale at Newegg until Thursday night.
I have the X650. Great product.
Jim
23 May 2012   #14
Trucidation
Just a heads up. I noticed we were having PSUs die on us fairly regularly and the culprit eventually was traced to an unstable (?) wall socket. What clued us in was the bulbs for the light on the wall the socket was on seemed to flicker randomly and also kept dying and needing to be replaced in very often (3-4 months per bulb). Moved the computer to a different outlet, hey presto, no more problems. Bad wiring I guess.
03 Jun 2012   #15
abyoung35
Yeah I've had that issue in an older house I lived in, our apts were built like 3 years ago so that's ruled out. I did get my psu installed yesterday, it finally arrived I've come the conclusion I need a bigger case though, but it all fits and so far so good, 2 days no bsod.
Hardware Power Consumption-Picking a new Power Supply-uploadfromtaptalk1338730460896.jpg
Bought new Power Supply Unit, won't power on. Did I buy the wrong one?
I have a Corsair CX430M PSU with 4 slots to connect in the back. CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com & bought a new Antec BP550 Plus PSU, which has 5 slots to connect to. Antec BP550 Plus ATX12V V2.2 80 PLUS Certified Modular...
PC Custom Builds and Overclocking
Video Hardware Error/Power Supply
Quick question: does a "Video Hardware Error" always mean the video card is at fault? Sometimes I get BSOD and "Video Hardware Errors" when playing video games. However, my computer often struggles to cold boot also, which I learned is often related to the power supply (it usually requires...
BSOD Help and Support
Power Consumption - 32-bit vs 64-bit?
Building a new HTPC and just curious if there's any difference in electricity usage difference from 32 and 64 bit setups. I'm trying to make it as energy efficient as possible.
General Discussion
Power Consumption
Hello - I am currently running Windows XP on a dell latitude e6400, but I'm strongly considering upgrading to win 7. However, I am very concerned about power consumption. The e6400 is energy star and currently consumes roughly 13 watts at idle when plugged in. I have heard very different...
Performance & Maintenance
Power Consumption Calculator
I remember such a thing being available on OCZ's website, or Corsair's, can't really remember. Do you guys know any good ones available? Thanks.
Hardware & Devices
Reducing Power Consumption with Windows 7ís Power Manag
More...
News
