No.
A "good one" is a PSU with adequate power for your particular requirements, from a reliable manufacturer.
You can all finds of lousy PSUs that have good specifications on the label. The specs for those PSUs mean very little because you don't know if the specs are true. And even if "true", under what circumstances were they measured? 840 watts for 10 seconds, then fails? 840 watts in a highly refrigerated room?
And you need to pay attention to TOTAL power. A PSU that has two 12 volt rails at 35 amps each may be able to supply only 700 watts total at any time.
Check reviews and comments at jonnyguru.com.
