Windows 7: USB Flash Drive power issue? (connect/disconnection loop)
26 Apr 2014   #11
raygrogan
don't know
Rats. So what did you do? The only options I see are learn to live without it (that is what has worked fine for about 4 months, but I would still like stuff I put only on that drive), or pay somebody to take the flash apart and move the data part to another flash.
What did work for the smaller files: Instead of trying to copy the whole drive, just copy a folder at a time. (Mine will keep power long enough to do this, yours sounds like it will not.) Then, as it is copying the power gets lost, and the "try again" pop up comes. My pro said best to wait until the second pop up comes, the scan again one, which means power is back. Then click scan only, then quickly click the try again while the getting is good.
This whole thing took about an hour for about 200 files, pretty much had to do all the clicks for each one, but I got them so good enough. But when I tried the same routine for picture files it mostly did not have enough time / power to get them. (This was on a different machine, the first success was on the IT shop's, maybe I will go back there.)
27 Apr 2014   #12
BrownChiLD
Windows 7 x64
My last option was just that -- to take it apart and transfer the mem/chip w/ an identical flash drive etc.. but i gave up on it before i could try
that's a good idea though w/ that letting the OS wait till the drive comes back online.. well, knowledge for the next time...
Removable Flash Drive Recognized as a Local Disk and not a Flash Drive
I recently purchased a 32 GB San Disk Flash Drive. The security files pre-installed on the drive were junk, and I could not delete them so I formatted the drive to remove them. This cleaned the disk, and it holds data, but I'm not sure if this is part of my problem. I am trying to load my copy of...
Hardware & Devices
Remote Desktop Connection won't connect after disconnection!
Hi, I'm running Windows 7 Ultimate x64 on my computers. Whenever i connection via Remote Desktop Connection, it works fine. If i try to connect again, it won't work where it times out! I have tried to shutdown the service and start it again but it doesn't work! The only way to fix it is...
Network & Sharing
flash drive format issue win7
flash drive or any card reader is perfectly working in windowx xp but when i insert in my windows 7 it show drive is not formated . then I formated on windows 7 it works but when i restart windows 7 it again show flash drive is not formmated . every time i restart windows 7 it does not open...
Hardware & Devices
Power Point Viewer won't loop
Just upgraded one of my users to Windows 7 with Office 2010 and she's having a problem with a Power Point presentation which she actually inherited from someone else. When viewing it in Power Point, it loops just fine. When viewing it with the Power Point Viewer, it doesn't. I made sure I have...
Microsoft Office
ERROR WHEN I CONNECT A FLASH DRIVE
Hello, Whenever I connect a pendrive/flash drive to my laptop I get this error message.:(But the most irritating thing is that it does not go !!:mad::mad:. CLICK, CONTINUE or TRY AGAIN it wont go. It wont go. Even after I disconnect my drive it shows error. I have to take that error window below...
Hardware & Devices
Windows is running really slow! + USB FLash Drive issue
Hi guys I have been using Win7 for about a week and it has been getting incrementally slower every day. Here are the steps I have taken so far: I have disabled every service I can disable without compromising the functionality of the OS. This includes Superfetch and Indexing. I have...
Performance & Maintenance
