Wireless printer super-slow, firewall problem? how to fix?
nwislander
2:24 AM
Bainbridge Island, WA
Had to re-install HP4500 AIO printer after getting new wireless router. Not sure if it makes a difference, but am using WPA encryption now -- previously no encryption. Anyway, the printer software is installed on 2 laptops, one is Vista, the other (main computer) is Win7 x64. Using either one of these to send a 10-charracter Notepad document to the printer, it takes like 3 minutes for it to print out.
At one point during a test-print from the HP installation routine, I got a message about problems connecting with the printer and instructions to make sure the firewall was configured such that a certain port would allow the printer to work, but lost that window while I was trying to figure out how in the heck to see port settings and/or change them.
Appreciate any advice!
Windows 7 x64 Home PremiumIntel Core2 Duo P87004 GBnVidia GeForce 9600M GT
HP HDX16
NVIDIA hi-def audio
ST9500420AS ATA 7200rpm
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
ANTEC Three Hundred Illusion
85 + Mbps
Vivaldi
Easiest way to test if a firewall is maybe interfereing is to ping the printer's ip address if it times out then chances are the firewall is the culprit.
Windows 7 Ultimate x64AMD turion 64x2 TL-64 2.2GhzSodimm DDR2 4GBATI Radeon 1250 128MB IGP
HP Compaq 6715B
HC030
Sodimm DDR2 4GB
Fujitsu Siemens 500GB sata 3.0 Gb/s
Hi nwislander, Welcome to the forums, another thing to check is ,In the printer device properties make sure to put a check mark against "print directly to computer" this will speed things up :D
win 7 ultimate32bit, Win8.1pro wmc 32bitamd phenom x4 9600corsair twinxs 2x2gb2x nvidia 1gb 8500gt
self build
amd phenom x4 9600
asus m2n32-sli deluxe
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
thermaltake xaser lll
artic freezer64 pro + 7 case fans
Binnngggg-go! "print directly to computer" did the trick! Have to say, it's kinda counter-intuitive (to me). I thought I was printing "from" the computer:confused: What does "print directly to computer" mean exactly? Thanks!
HP HDX16
NVIDIA hi-def audio
Thanks to A Guy and TheCyberMan too, both of those tips will come in handy for future problems I'm sure.
And thanks for the Welcome.
HP HDX16
NVIDIA hi-def audio
Yeah, Pebbly is the smart one ;) A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
85 + Mbps
Vivaldi
Nice pebbly.
HP Compaq 6715B
HC030
Sodimm DDR2 4GB
Hi nwislander, It means that processing documents are done by the computer memory instead of using the printer memory ,that's the easiest way to describe it :D
Thankk you A.Guy and The cyberman for your kind comments , really appreciated :thumbsup:
self build
amd phenom x4 9600
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
