Windows 7: Power options problem
03 Jul 2012   #11
ICIT2LOL
Yeah my mains varies between 242 and 248acv but even so after rectification the final stage regulator should keep the output dcv at a steady voltage and even the older types would within+/- 0.1v of stated or required voltage especially if one wa using one of the variable circuits.
I'll see if I can dig some out for reference.
Win 7 Power Options or HP Power Manager ??
Okay-I'm confused.And,I've been wondering about this since I bought this pc about 2 years ago ! I have a Compaq Presario (HP) CQ57-229WM Notebook PC that I bought from Wal-Mart a couple of years ago and this machine seems to have TWO "power plans" on it ! Why ??? It has the HP Power Manager...
General Discussion
Power options/brightness problem!!!!
Hi, I've this issue from day one! I bought my Toshiba Tecra R840 almost 2 years ago (Win7 Pro, i7, 8GBRAM, 512 GB SSD,...). What about the issue: My Power Options are: when running on battery: brightness=40% when plugged in: brightness=100% If I click apply, this would be ok for a...
Hardware & Devices
Power Options Problem
I am using Windows 7 32bit and although I am setting the power options to turn off the display after 10 minutes nothing happens and the screen does not turn off Any help would be much appreciated regards Brian
Performance & Maintenance
How to set Advanced options in Power Options (64 bit Ultimate)
I have an older Belkin F6C1500-TW-RK UPS and the mfg has not offered software management for the Win 7 64bit OS. I want to let Win 7 manage the battery and shutdown. I set the High Performance under Power Options to turn off display and put the computer to sleep after 3 minutes as a test. I yanked...
Power Options
Hello. How can I setup Windows 7 to turn off the Hard-Disks (after an idle time), but keep the boot Hard-Disk On? Thanks!
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
