Windows 7 64bit Manual Power cut Required for normal startup..(HELP)
trev ek9
1:00 PM
Hi guys... new to this forum
My comp specs follows:
M.board: biostarTh55b HD (t seiries board)**
Intel i3 CPu 530@ 2.93 ghz
Crosair Memory: 4gb dual channel DDr3 (CMV4GX3M2A1333C9)
Raidmax mod # Rx -380 k (power supply)
Segatge Barracuda 7200 HD
please let me know if there is more info I should have for specs//
If I can explain properly is as follows: When the computer is shut down for a period of time (usually left over night) upon rebooting.. (pressing the on switch), it brings me to the start up repair/start normal screen. If i repair or start normal i am sent to a loop that usually send me back to repair/srt normal screen after (Tseries board screen)**
If i manual cut power at power supply and restart the computer it usually will restart without a hitch. (This means i must manually click the power button on the back of computer on the power supply or unplug computer from wall...)
I have tried to check memory when i start at the bios screen by pressing i believe f11 (for me) and the check has not found anything wrong.
The computer usually runs flawlessly when i have it running but I have had a couple of blue screens.
I have recently wiped the hard drive and done a full new re_intsall of windows 7 64 bit and that has not seemed to solve any of the problems.
I hope someone can help me or knows if this could be a certain kind of problem so that I can eliminate things that it def is not
Thanks everyone in advance and please feel free to ask me to post more info as I am a real newb when it comes to this stuff
windows 7 64 bit
windows 7 64 bit
Windows 7 Ultimate 64 bitAMD Phenom II X4 965 Black EditionGSkill 4 X 2 GB PC 8500XFX Radeon HD 6790 D
Custom built
Gigabyte GA-MA790X-DS4
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
Custom built
On board RealTek HD
1600 X 900
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
