Combining two hard disks in to a single drive on Window Home Premium
Page 2 of 2 FirstFirst 12
  1. Posts : 6
    Windows 7 Home Premium
    How about the attached?
    Attached Thumbnails Attached Thumbnails Combining two hard disks in to a single drive on Window Home Premium-printscreen.png
  2. Posts : 12,012
       #12
    That looks as expected. The SSD has System Reserved and C. The large drive is empty.
    I assume you store all your stuff in some folder under C Users, most likely C users yourusername?
    You need to redirect that folder.
    I have never used user folders at all and save directly to the D drive, so I'm not the authority on what you need to do---but it is commonly done.
    Below are a couple of tutorials that you can at least look over. I'd wait for others who have actually done the procedure to comment as I think there may be some nuances or there may be other relevant tutorials.
    User Profile - Change Default Location
    User Folders - Change Default Location
  3. Posts : 5,795
    I would recommend not redirecting folders, but just changing the library pointers. That used to be the way, but I see most people suggesting to not redirct anymore with Windows 7. On any system I use, I don't store anything on C on purpose. Everything goes to my D drive...docs, photos, music, etc.
  4. Posts : 3,371
       #14
    I created folders on my D: drive similarly named to the ones on my C: drive. For instance, I have Music, Pictures, Video, Program Files, etc... When I save a data file, I simply save it to the folders I created on the D: drive.
    I don't install ALL of my program files on my SSD but only those that I use frequently. I also moved the page file and TEMP file folder to the D: drive.
    When installing a program, it's easy to tell it to install on the D: vs. the C:. The default is usually to install to the C:\Program Files\ProgramName folder. Since I have the Program Files folder on my D: drive I simply change the install drive from C: to D:. Many programs require you choose "Custom Install" to be able to alter the default install location.
  5. Posts : 5,795
    That's exactly how I have all of my systems set up, and then I just change the Libraries to point to those folders and only those folders.
  6. Posts : 12,012
       #16
    I do something similar, but I don't use libraries or user folders.
    I have folders on D named downloads, mp3, pictures, video, etc and save directly to those folders.
    I can't remember when or exactly why Microsoft introduced the "user folder" thing, but I never saw any need to get involved with it. Was it on XP that they first appeared? Or Windows 98?
    Likewise, libraries don't add anything I need.
    Here is another tutorial by Kari that may be pertinent for the OP:
    User Profiles - Create and Move During Windows 7 Installation
    I think I saw a post by Gregrocker in the last few days in which he said that the best method is to COPY user profiles to D, rather than move them.
