Windows 7: Wireless LAN adapter not working after system restore.
17 Jul 2012   #1
voxel8tor
I recently restored my PC, well, actually just reformatted the hard drive, and loaded windows back onto it. I only had the disk with the driver software for my motherboard, And not for my graphics card and WLAN card. I knew my WLAN card wasn't working because the driver softare was lost in the reformatting so I brought my computer downstairs and plugged it into the ethernet. I downloaded the drivers for my graphics card and it worked fine, then I moved on to getting the drivers for my WLAN card. I wasn't sure what driver to download so I opened up my computer and took the WLAN card out, I found the model but there were no drivers for that model, so I tried a few different ones and they all said that my WLAN card is disabled, when I researched how to enable it on google I found nothing. I went to the device manager and under networking devices I only found the gigabit ethernet adapter, but under other catagory, I found "network controller" and it had a yellow ! sign, I thought that that could be my WLAN card, and apparently windows couldn't find the driver for the "network controller" that i saw on the device manager. So in conclusion to this super long forum thread, I have no idea how to fix my WLAN card, and need any help I can get. I entered my computer info when I registered on the forums, so I'm not going to put it here, if anyone needs it though, I'd be happy to give it to you.
Wireless LAN card: Ralink wireless PCI adapter the chip number/Id is RT3060
17 Jul 2012   #2
HonorGamer
Windows 8.1 Pro x64
I have actually researched this model of LAN card, and the only thing I am finding on it is for Linux. i do not see anything for windows.
I looked on the companies website and i seen this version to be close:
Ralink-A MEDIATEK COMPANY.
It may not work, but try that out.
17 Jul 2012   #3
voxel8tor
Quote   Quote: Originally Posted by HonorGamer View Post
Thanks, I'll see how it works. I also forgot to mention that it worked before the system restore, so if this card is only for linux, the guy I bought the computer from probobly did some custom coding to get it to work, but I guess that's unlikely.
17 Jul 2012   #4
HonorGamer
Windows 8.1 Pro x64
It would be unlikely that they would do that. I mean in the past i have installed drivers not for that exact card, but it has work. So give it a shot and post back the results.
17 Jul 2012   #5
voxel8tor
It worked! Thanks so much! I was at the brink of throwing that WLAN card out of the window! I spent all day trying to get the thing to work again.
Wireless adapter not working
My computer will not even load the wireless adapter it says This device has been disabled by the wireless button and cannot be enabled from the Wireless Assistent and I looked and not even loading it up.
Network & Sharing
Hello, I need help! Two days ago my wife's computer would not connect to wireless networks anymore. It said that "No connections are available". It used to tell us to turn the switch in the front of the computer on, however it is on. (Now it will not troubleshoot, I receive an error during...
Network & Sharing
RDP not working with new wireless adapter...
I recently purchased a Tenda W311U wireless adapter for a machine in a second room. Plugged it in, Windows 7 loaded the drivers and it was good to go. I set it up to be an RDP server, was able to connect to it without issue. The only problem I had with the Tenda adapter was the range & power, so I...
Network & Sharing
Wireless Adapter not working
I have a Canyon CNP-WF511 that just will not work. It installed on Windows XP and ran fine but now windows now installs the drivers and thats it. Nothing else. The card doesn't appear on the list of network cards. Then though after a few restarts it asks for the drivers again. Also the card...
Hardware & Devices
wireless adapter not working
hello,, recently i've bought tp-link tl-wn721n wireless usn adapter.. dont know wether already install properly or not.. but i found wireless icon in network..it said "Enabled".. when i tried to create adhoc...cannot.. what shud i do? is it this usb adapter can create network n access...
Network & Sharing
Wireless USB adapter not working
Hi everyone, I recently bought this adapter. Plugged the item into my desktop computer (specs: gigabyte p55m-ud2, Radeon 4890, Windows 7 32-bit) and it would automatically install the drivers, BUT that's all it would do. Then several minutes later it shoots me a popup saying: "Windows found...
Network & Sharing
