User problem connecting to Network drive.
  1. Posts : 17
    Windows 7 32bit
    Hope someone can help. spent a few hour now scratching my head with this.
    We have a NAS at my place of work that some people can connect to and some can't.
    even though I have full network admin rights I can not connect to it but most users can.
    I have tried changing the security setting to not us Group policys and its not made any difference.
    I use the run box ie \\devicename\folder to connect but it wont work.
    the NAS is plugged directly into a switch via a ethernet cable.
  2. Posts : 1,436
    Windows 8.1 Pro x64
    What is the model of your NAS? This may help me figure it out.
  3. Posts : 17
    Windows 7 32bit
    Hi there. its a Iomega StorCenter ix2-200
  4. Posts : 1,436
    Windows 8.1 Pro x64
    Are you able to connect to the NAS via browser?
    This is a new one for me, so what you learn I am also learning. I'm also doing a lot of researching into this so that could be the reason for late replies.
  5. Posts : 1,436
    Windows 8.1 Pro x64
    Do you have something like bitdefender installed?
    Also, does the device show up in the network?
    Control Panel -> Network and Sharing Center -> See Full Map
    Post a screen shot of the full map.
  6. Posts : 17
    Windows 7 32bit
    yes I can access the drive via the web interface so I can make changes etc. its just through explorer that myself and a few other can not get access.
  7. Posts : 1,436
    Windows 8.1 Pro x64
    Try connection to it through command line:
    net use [driveletter:] \\servername\sharename /user:username [password]
    Let me know if that works. This could also be a problem with network sharing.
  8. Posts : 17
    Windows 7 32bit
    It wont connect via the command line either. It will ping.
    the nas is showing in the full network map but have just noticed that the next to the Domain in brackets it is saying (Unauthenticated) wonder if that is the cause.
  9. Posts : 1,436
    Windows 8.1 Pro x64
    Do you have PAP(Password Authentication Protocol) enabled?
  10. Posts : 17
    Windows 7 32bit
    No it is disabled on the DC. believe this is disabled as default
