Windows 7: Problem with exFAT USB Flash Drive
19 Jul 2012   #1
Jalouly
Windows 7 Home Edition x86
Hi Everyone
I have recently encountered a problem when I first bought a USB Flash Drive 128 GB.
It's exFAT Format, Whenever I Add files to it, then re-plug it in, the files become corrupted, And i will not be able to open any.
I have tried to open the files but no luck :/,
I'm Using Windows 7 Home Edition and Dell Inspiron 1520 Intel Core 2 Duo, RAM
2.5 GB
Thank you.
19 Jul 2012   #2
mrdemon
Windows 7 Home Pre
What size are these files. And Are you "Safely removing USB device" of just unplugging.
19 Jul 2012   #3
Jalouly
I'm safely removing it, and whatever the size of the file is. it keeps giving me errors
19 Jul 2012   #4
mrdemon
Windows 7 Home Pre
Have you looked on the site manufactures for a firmware update. Or Format it into Fat32 or NTFS
19 Jul 2012   #5
Jalouly
There is no luck into formatting it into NTFS, the formatting process always fail. Please help me, I really don't want to throw the Drive Away
19 Jul 2012   #6
whs
Microsoft MVP
exFat is not supported in Windows 7. Either you reformat or you donate the stick to someone who has and old OS. Try another formatting program.
20 Jul 2012   #7
Jalouly
I tried this software here HP USB Disk Storage Format Tool Download - Softpedia
but it didn't work.
I need your help seriously, this is the strangest problem I face :/
20 Jul 2012   #8
whs
Microsoft MVP
20 Jul 2012   #9
Layback Bear
Windows 7 Pro. 64/SP-1
What brand of flash drive do you have. Their has been reports of many counterfeit flash drives that just don't work.
EXAMPLE.
http://www.amazon.com/Kingston-DataT...owViewpoints=0
Kingston Technology Company - Company - Memory Verification
20 Jul 2012   #10
Jalouly
ok well I converted the Flash Drive from exFAT to FAT32. but I don't see any difference. I tired the program you gave me and still no luck :/
I got the flash drive from china, maybe it's a poor type or something ?
How do I format a hard drive to exFAT
I'm currently trying to format a hard drive to exFAT. It's not my main one it will be used for sharing files on my home network. Apparently you can do it just by right clicking the drive and choosing format however I just have the NTFS option, I don't have exFAT. Is there something else I need to...
Hardware & Devices
Formatted External HD as exFat - Windows does not read drive...
Hey folks, I just reformatted a 350gig external hard drive as exFat so as to be able to use it with both Windows at home as well as Mac's - but now it seems my laptop does not read the drive ie I can't see it in MyComputer - although I can still safely remove for some reason. :confused: I...
Hardware & Devices
Problem with Bootable Flash Drive
Remember the good old days (MS-DOS 6.22) that your system is running great and then one day it doesn't boot? You immediately put in a disk into your drive, boot the system up and that great looking "A" prompt would be there? How can I do that with a flash drive? I've tried at least 1/2 a dozens...
General Discussion
problem installing from flash drive
i have a very long story but i will try to keep it short. if you need more information to help me let me know. so in short. i just put a new hard drive in. set my bios up to boot from usb flash drive first, then cd rom. well i had both the cd and the flash drive in, i'm not sure which one it...
Installation & Setup
Flash drive problem
I have probably about fifteen folders on my USB flash drive, each of which contains valuable information (all text files). On one particular folder, when I click it, the contents of that particular folder (the files) appear - only they all have messed up titles and won't open. On all the other...
Hardware & Devices
Flash Drive Problem
Here's the problem, whenever I pop in my 1GB Cruzer Micro flash drive, autoplay opens up and shows me this http://imgur.com/ECnn8.jpg There is no CD on the flash drive at all, I have tried formatting the flash drive and it still comes up whenever I plug in the flash drive, and it shows up as...
Hardware & Devices
