seagate 250 GB SATA write-protected problem
  1. MoD
    Windows Ultimate 32-Bit, Windows Enterprise 32-bit
    hello guys,
    yesterday my brother gave me a desktop computer
    Here is the SPEC:
    HP Compaq dc7800
    Core 2 Duo E6750 @ 2.66GHZ
    2 GB ram "Dual channel 1 GB each”
    250 GB Seagate barracuda 7200 SATA
    no graphics card yet “will buy one soon"
    i tried to install windows 7 because there was no system on HD "New HD" even when i start-up the computer, it told me new device configuration "Seagate 250 GB"
    Anyway, the installation stuck at expanding windows files 0 %
    I tried to use USB instead of DVD but it stuck at first screen "windows is loading files"
    Also tried to install XP but in installation it gives me blue screen and told me to do CHKDSK /F
    When I do CHKDSK /F from windows 7 DVD repair ... it gives me error
    This disk is write protected!!
    i searched the internet looking for solution but no luck
    Tried to use diskpart tutorial...
    Change setting in bios... even updated the bios
    Install HD on other computer... i can transfare files to the HD with no problems
    But none works
    Now I’m totally lost what should I do??
    and if i may ask, does these Hard-Drives have jumper because mine don't
  2. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Hi, where did the drive come from?
    As for jumpers, you answered your own question, no jumpers.
  3. MoD
    oh hi again ....
    if you mean the HD ...honestly i don't know but the old HD got currpted so my brother replace it with the 250 seagate and gave me the PC
  4. Posts : 24,479
    Did you try running diskpart /clean all with the W7 DVD? When you get to the screen asking for location press Shift + F10 and a command prompt will open.
  5. MoD
    hmmm,
    i did clean now but didn't change a thing
    still stuck at expanding windows files 0%
    but thanks anyway:)
  6. MoD
    oh sorry... i did only clean last time...
    now i did clean all i suppose it will take some time
    will post replay to tell you what happend...
  7. MoD
    ok...
    nothing changed, i did the CHKDSK /F and give me the same error
  8. MoD
    new info ....
    when i do detail disk
    current read-only state: NO
    read-only :NO
    etc also NO
    so it can't be write-protected ?? right ?
    Note: the error message i got is Volume write-protected not disk
  9. Posts : 24,479
    If you have access to another computer, attach the HDD to it and see if your can format it. Put back in your computer and try again.
    Is the HDD connected via SATA cable directly to the motherboard?
  10. MoD
    ok i will attach it to my home computer and format it
    yes it's connected directly ...
