Windows 7: PC case upgrade gone wrong, need help. Hardware/software problem.
23 Jul 2012   #31
PSCO2007
Windows 7 Professional X64
Quote   Quote: Originally Posted by BigDaddy0790 View Post
Quote   Quote: Originally Posted by PSCO2007 View Post
Update 2: Tried using SeaTools for Windows by Seagate, their diagnostic utility. Tried short Generic test, it passed. Short drive self test (DST) failed. Both passed on my newer 1TB drive I just bought for storage. Should I take more tests or just try to fix it with the utility? Or just screw it and get a new drive instead of this one? I really don't want to do that.
Download the Dos test - burn to cd - this is a very comprehensive test.
Run the LONG test.
SeaTools | Seagate
A bit late for that, I'm in Germany atm, aka not at home. Decided to get a new Windows install and new HDD anyway, just in case it all gets fixed 100%.
I still want to know what that Windows backup thing does. Do I get a full copy of my HDD, meaning I can copy it to another HDD and then just remove this one booting from the new one?
I use the Acronis Discwizard ( link I gave you).
It is fast and will backup the drive and allow you to restore your system in case of a failure or corruption.
24 Jul 2012   #32
BigDaddy0790
Well, clean install is no problem so I guess I'll just do that. Buy another HDD and copy data there, then return mine and get another like that, will even have a new HDD after all this. At least something positive I guess.
08 Aug 2012   #33
BigDaddy0790
Alright, came back home yesterday, did a clean install today. New HDD, new Windows, it seems to be working for now at least. I only got this question, how do I change system language? I have my old German install disk and while I change most of the text using the language pack, I remember having trouble changing ALL of it. For example, Windows Update section is still all German, and I can't delete it from packs because it says "system language". I totally got rid of it before though, but now can't seem to find a solution on Google for some reason. Anyone knows a way?
Update: Solved itself. Language simply changed to English after yet another update-reboot. All working fine now, so I'm guessing it really was the HDD. Thanks for the help to everyone!
Unsure if its a Software or a hardware problem
Bought a Dell L521X more than a month ago and I am having problems. I am running Windows 7 Professional. This has happened to me once already. And it just happened recently. When I am browsing the Internet or doing anything, the computer gets stuck. I cannot do anything. Mouse doesnt work....
Performance & Maintenance
Random BSOD - hardware or software problem?
Hallo everybody, I hope you can help me. I have continuos BSOD or pc freezing since two months. Dont know if it is an hardware, software or virus problem. I tried different programs and tests, but the pc still has this problem. This is a work station that run only original programs. I send the...
BSOD Help and Support
Virus or Software or Hardware Problem?
Win 7 HP has developed an extremely vexatious problem!!! When logging on or typing in Search or typing in Chrome even typing in Word or email. the number 8 keeps repeating itself continually eg; 888888888888888888888888888888888888888888888888888888888888888888888 etc etc. Even if this key...
General Discussion
Laptop Windows 7 Problem/Software/Hardware? Keyboard problem
Okay, right now I'm currently trying to find out whats wrong with a keyboard that is on a laptop, after the computer starts there are some script errors, I don't know exactly what they are but I ran combo fix without safe mode and restarted the scripts went away...and it started working after...
Hardware & Devices
RAM upgrade problem-Wrong DDR
I have a Dell XPS M1530 with 3GB of Ram. I wanted to upgrade my laptop to 8gb of Ram so I got RAM as a Christmas present. It was DDR 3 RAM at 204 pin. I came to find out that I actually needed DDR2 at 200pin. I believe I can return them but here is what really sucks: all the DDR2 Ram is...
Hardware & Devices
BSOD, software or hardware problem?
I think HDAudio.sys is the problem but I'm not sure. can somebody check my dump file ?
