4pin of a 20+4 pin mobo power was n0t plugged in. What happens?
Jonesie85
11:39 PM
Hello, i have some simple questions. My system randomly turns off. no blue screen. No crash dump. no windows shutdown screen. This isnt really about the shutdowns.
1 - What happens when the 4pin connector of a 20+4 pin mobo power plug is disconnected
2 - Does the 4pin connector give more stability to a pcie2.0 x16 Graphics Card?
3 - What damage could have been done?
Ive swapped the graphics card out with a Power Color HD4850. The shutoffs happened with both.
I have four ram chips. i took out 2 and it still shutoff. Im now trying the other two.
Thank you for your time.
Windows 7 Home x64 & Windows XP Pro x86AMD Phenom II 1100T x6.Corsair Vengeance 4x 4gb 1600mhz.XFX Radeon HD 6970 + Arctic Cooling Accelero ...
User-built (and proud of it!)
Asus Sabertooth 990FX r2.0
XFX Radeon HD 6970 + Arctic Cooling Accelero Twin Turbo II
Onboard 7.1 Creative X-FI.
LG 42LK450u 42" LCD HD TV
1920 x 1080.
2x WD 20EARS 2TB.
Fractal Design Newton R2 1000W Modular.
Antec 1200 V3 Full Tower.
Zalman CPU Cooler CNPS9900-MAX Blue.
Trust Media Centre with Built in Trackball.
Logitech Trackball.
4.3 Mb/s download and 1.2 Mb/s Upload
1x200mm Antec 3-speed Blue LED Fan.
5x120mm Antec 3-Speed Blue LED Fan.
Samsung Writemaster Sata DVD-RW.
2x300mm Blue Cold Cathodes.
2xBlue Cold Cathode Rods.
To answer your questions, I really don't know. But, I would suspect the +4 pin will supply more power to the motherboard. The 20 pin will supply enough power for it to run but not quite as much as it should have. I would not worry too much about any damage to the board. The GPU gets most of it's power from the pcie conntections, but the extra 4 pins may help. As far as the memory, I would suggest running memtest86 to test the memory. The link is to a tutorial on how to run it. You are looking for bad ram sticks or defective dimm slots.
    ALWAYS UNDER CONSTRUCTION
    Windows 11 Pro
    Ryzen 9 5900X
    Asus X570 Crosshair Viii Hero
    32GB G Skill DDR4-3600
    EVGA RTX 3080 FTW 3 Ultra
    3 X Asus 27"
    2 X 1 TB NVME drives
    EVGA 850
    Phanteks Eclipse P400A
    EVGA 280 AIO
    Logitech G510s/ Logitech G13
    Logitech G502
    ESET/MBAM Pro/SAS Pro
    Chrome/ Firefox/ Edge
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
on 20+4 atx plug the 4 additional pins give more power that pc demands nowadays, especialy with high end GPU.
if its not connected motherboard tries to draw all the power from 20 pins.. that may be okay but in extreme cases where lots of power are used it may melt wire or connector, because current is too high. or it may just add stability problems when system dont get enough power.
Windows 7 pro 64bit. (SP1)Intel core I5 24008GB DDR3 KingstonGigabyte GF GTX650OC
Self Built PC
Intel core I5 2400
Gigabyte H61
8GB DDR3 Kingston
Realtek HD audio
LCD 20"
1600x900
INTEL SSD 320 80GB +Seagate 7200.12 1TBx3
Coolermaster RX450W
Coolermaster atx case
stock cooler
logitech
logitech
FTTD 100mbps
I'm surprised it booted without giving you a warning or a message to click through.
Intel Core i7-2600
Gigabyte GA-P67A-UD3P-B3
Nvidia GTX 470
Dell UltraSharp 2209WA
OCZ ModStream 700W
CoolerMaster HAF 912 Advanced
CoolerMaster Hyper 212 Plus
