Flash Drive to USB Insertion Problems
  1. Posts : 3
    Windows 7 Home Premium 64bit, Windows 7 Professional 32Bit
    When I insert certain USB flash drives into the USB port, The Flash Drive is not recognized by the computer. It happens with same drive in all USB ports on the computer. Other Flash Drives work properly.
    Also, with Flash Drives that are recognized, the computer will shut down and reboot on inserting the Flash Drive.
  2. Posts : 10,200
    greyhair,
    Welcome to SevenForums.
    The problem that as soon as you insert a USB stick the computer shuts down is the more serious problem.
    That problem I've never seen, but implies to me that your computer has some nasty malware.
    I'm going to give you a write-up for a procedure that will remove all of your malware.
    The procedure is written for using USB however you can use a DVD.
    If you have any questions, you will notice that the Microsoft site where you will download the program has instructions for using either usb or DVD.
    HOW TO USE WINDOWS DEFENDER OFFLINE ON A USB STICK
    Windows Defender Offline
    · is a free standalone, bootable malware and virus remover from Microsoft.
    · performs an offline scan of an infected PC to remove viruses, rootkits and other advanced malware.
    Download Windows Defender Offline (about 764 kB)
    You will have the choice of downloading the 32bit version (x86) or the 64 bit version (x64).
    The link will help you determine whether you are running a 32 bit version or 64 bit version of Windows
    NOTE!! You can download and prepare a 32 bit version using a 64 bit version of Windows
    NOTE!! You can download and prepare a 64 bit version using a 32bit version of Windows.
    You run the 32 bit version on a 32 bit version of Windows.
    You run the 64 bit version on a 64 bit version of Windows.
    The 32 bit download file name is: mssstool32.exe
    The 64 bit download file name is: mssstool64.exe
    For the curious, this program was originally name Microsoft Standalone System Sweeper.
    INSTALLATION:
    You will need an Internet Connection.
    Insert 512 mB (Microsoft’s 256 mB is no longer accurate) or larger USB stick into a usb port.
    Run the downloaded program--mssstool64.exe or mssstool32.exe
    NEXT button
    Choose the option On a USB flash drive that is not password protected
    NEXT button
    NEXT button
    The install program will format the usb stick using the NTFS format.
    The install program will download about 210 mB.
    The install program will name the USB stick WDO_Media32 or WDO_Media64
    The WDO_Media32 usb stick will have used space of 255 mB (268,140,544 bytes)
    The WDO_Media64 usb stick will have used space of 282 mB (296,165,376 bytes)
    You can expect the number of mB to increase as more malware appears.
    UPDATE Windows Defender Offline USB stick:
    · reinsert the usb stick
    · run the installation program, mssstool64.exe or mssstool32.exe, again.
    · the update will download about 66 mB (mssstool32.exe) and 68 mB (mssstool64.exe).
    Since the malware database is sometimes updated several times in a day, always update before running.
    PERFORM AN OFFLINE SCAN
    Bootup your computer from the USB stick
    Windows Defender Offline will automatically perform a quick scan.
    After the quick scan finishes, Choose Full Scan
    Select all of your drives
    The initial, full scan can easily take several hours, but
    Remember, your computer is being very thoroughly checked for all types of malware.
  3. Posts : 3
    Did the windows defender work yesterday. It took about 6 hours but nothing was found. Also did a RAM check with Memtest86 which showed nothing. Also ran a sfc scan with no results. I think the ext thing to do is a Repair Install. Suggestions are welcome.
  4. Posts : 2,240
    Windows 7 Ultimate 64 bit
    I would suggest doing a system bug check of Malware, spyware and adware...trojans, worms and the like. Run all your malware software in safemode with networking, doing full scans on each. This will take a lot of time so be patient. Some suggested software to use.
    Malwarebytes
    Spybot S&D
    SuperAntiSpyware
    Adware
    These are all free and can be downloaded and installed/update in safemode.
  5. Posts : 10,200
    Bassfisher:
    1. WDO will have removed everything. WDO is the most complete approach.
    2. We do not recommend the use of Spybot or of AdAware.
    3. With MSE installed, then SuperAntispyware is senseless and counter-productive.
    4. once a system is clean the MalwareBytes is not needed, however, does no harm and plays will with MSE, microsoft security essentials.
  6. Posts : 10,200
    Question: did you run at least 6 passes with memtest86+ ?
    Next: carry out following which will allow me to see the results, etc from using WDO.
    # **********************INSTRUCTIONS**************************
    # STEP 1 ** RUN POWERSHELL AS ADMINISTRATOR ******************
    # WIN key | type POWERSHELL | do NOT hit ENTER |
    # in the PROGRAMS list, right-click on WINDOWS POWERSHELL |
    # choose "Run as administrator" |
    # Click on the YES button (if such appears)
    # WIN key = key with Microsoft log on top
    # for the guru:
    # WIN | type POWERSHELL | CTRL+SHIFT+ENTER key combo | ALT+Y keycombo
    # STEP 2 ** COPY AND PASTE ***********************************
    # COPY the script using CTRL+C,
    # COPY every line of script down thru both EXIT statements
    # PASTE into Powershell
    #----Right-Click at the PowerShell Prompt
    #----(Ctrl+V does not work)
    # Start copying with first script line without a # at start of the line
    # Note: Actually, you can paste the entire file if you rather
    #-------Lines starting with a # are ignored by PowerShell
    # STEP 3 ** SCRIPT OUTPUT & SCRIPT PURPOSE *******************
    # --The script output and purpose is given at the very front of the script
    # ***************** NOTE - POWERSHELL VERSION*****************
    # if you receive this error msg:
    #--The system can not find the path specified
    # you may need to update your PowerShell
    # you must be using Powershell 2.0 or later.
    # To determine your Powershell version:
    #---Run PowerShell
    #---enter $host.version
    #---you should see at least:
    # Major Minor Build Revision
    # 2......0......-1.....-1
    # If you do not see the above, update your Vista/Win 7.
    # *************** NOTE - EXECUTION POLICY*********************
    # If you haven't set the execution policy, you may need to:
    #---Run PowerShell
    #---enter SET-EXECUTIONPOLICY -EXECUTIONPOLICY REMOTESIGNED
    Script:
    # Zips up your log files from Windows Defender Offline
    #  and extended info about the log files
    # Places WDOlogs.ZIP on your Desktop
    function New-Zip {
    param([Parameter(Mandatory=$truePosition=0ValueFromPipeline=$true)]
    String$Path, [Switch] $PassThru, [Switch] $Force )
    Process { if (Test-Path $path) {if (-not $Force) { return } }
    Set-Content $path ("PK" + [char]+ [char]+ ("$([char]0)" 18))
    $item Get-Item $path$item.IsReadOnly $false;if ($passThru) { $item } } }
    function
    Copy-ToZip {param(
    Parameter(Mandatory=$true,Position=0,ValueFromPipelineByPropertyName=$true)] [Alias('FullName')]
    String]$File, [Parameter(Mandatory=$true,Position=1)] [String]$ZipFile,[Switch]$HideProgress,[Switch]$Force )
    Begin {$ShellApplication = New-Object -ComObject Shell.Application
    if (-not (Test-Path $ZipFile)) {New-Zip $ZipFile};$Path Resolve-Path $ZipFile
      $ZipPackage
    =$ShellApplication.Namespace("$Path")}
    Process {$RealFile Get-Item $File; if (-not $RealFile) { return }
      if (-
    not $hideProgress) {$perc +=5; if ($perc -gt 100) { $perc
    Write-Progress "Copying to $ZipFile$RealFile.FullName -PercentComplete $perc}
    $Flags 0; if ($force) {$flags 16 -bor 1024 -bor 64 -bor 512};Write-Verbose $realFile.Fullname
       $ZipPackage
    .CopyHere($realFile.Fullname$flags);Start-Sleep -Milliseconds 500}}
    $fileinfo join-path $env:TEMP \wdofileinfo.txt
    IF (test-path $fileinfo) {del $fileinfo -ea:silentlycontinue -force:$true}
    $dir $env:windir '\Microsoft Antimalware\Support'
    $a dir $dir  -rec -force -ea:silentlycontinue sort-object -property lastwritetime
    $b
    $a where {$_.extension -eq '.log'} |Select  modefullnamenamecreationtimelastwritetime,  lastaccesstimelengthextension
    $b
    out-file -append $fileinfo
    $b
    | foreach ($_.fullname) {get-content -path $_.fullname} | out-file -append $fileinfo
    $ziploc
    $env:userprofile '\desktop\WDOlogs.ZIP'
    new-zip $ziploc -verbose:$false -ea:silentlycontinue -force:$true
    copy
    -tozip  $fileinfo $ziploc -verbose:$false -hideprogress:$true
    del $fileinfo
    EXIT
    EXIT
    That will put a ZIP file on to your desktop. Attach the ZIP file to your next post.
    If you are eager to reinstall, then despite the title of this tutorial, all cases are covered:
    Clean Reinstall - Factory OEM Windows 7
  7. Posts : 26,869
    Windows 11 Pro
    What brand make and model case do you have?
  8. Posts : 10,200
    Greyhair,
    In line with the question from Essenbe, please carry out following:
    Update your SevenForums System Specs
    User CP (located on the top menu bar) |
    Your Profile | Edit System Spec
    (left-hand column)
    To gather info, use Speccy (my favorite) or SIW or System Info
    In the System Manufacturer Block, enter:
    Manufacturer and Model and
    ADD the word laptop, desktop, netbook or tablet.
    For example:
    Toshiba Satellite L305D notebook.
    Provide full windows version info, for example:
    Use the “Other Info” block for Optical Reader,
    Mouse, touchpad, wifi adapter, speakers, monitor, etc
    Scroll down and click on SAVE CHANGES.
    You will find that in Speccy, you can select info from the display
    using your mouse/touchpad and then paste that info into your specs.
    SIW is a marvelous program, but the free version does not offer
    this capability.
