Connecting a second monitor using a TRENDnet USB/VGA KVM Cable
MrRob89
9:00 PM
I recently purchased an HP Omni 120; it doesn't have a VGA port but plenty of USB ports, and I found a TRENDnet USB/VGA KVM cable and I attempted to attach it to my computer an external monitor, but an error message popped up saying that it doesn't recognize the driver.
I learned that KVM is hooking up multiple computers with the same keyboard and mouse, but I wanted to know if I could use this cable for simply extending my display onto a second monitor without purchasing a KVM switch -- is there a driver or alternate method that would work? Or is there recommendations for a good, cheap USB/VGA cord?
Windows 7 Home Premium 64-bit
HP Omni 120
Windows 7 Ultimate 64 bitAMD Phenom II X4 965 Black EditionGSkill 4 X 2 GB PC 8500XFX Radeon HD 6790 D
Custom built
Gigabyte GA-MA790X-DS4
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
That is what you need. I actually used two of them for a clients laptop to enable a triple desktop for his stock trading program. Your monitor needs to have a dvi port though, it's a wide white multi pin connection, that looks like the end of the startech adaptor.
There are other models that do USB to VGA if that is the only connection your monitor has.
The cable you purchased wont work for what you want.
Windows 7 Ultimate 64bitIntel i7 3770K16GB DDR3 1333 Corsair XMS3XFX HD6950 2GB EyeFinity
HAL-9000
Intel i7 3770K
Asus Sabertooth Z77
Logitech G35 & Sennheiser PC135 & VIA HD
23" HP 2310e, 23" Samsung B2230, 21.5" Viewsonic
5760x1080
16TB of Storage
128GB & 256GB Crucial M4 SSD's, 2X 1TB WD Black, 3x 2TB WD, 3x 2TB Samsung F4, 1.5TB Seagate, WD 500GB,
Antec True Power New 650watt
Cooler Master HAF-932
Corsair H60 Hydro Cooler, 3x 230mm Fans, 2x120mm Fan
Logitech G15 and G13
Logitech G700 Gaming Mouse
50/10 Mbit
Speakers : Alesis M1 Active Mk2 Studio Monitors , APC RS 1200 UPS, HP 4500DN Color Laser, HP P1006 mono Laser, Kodak 8500 Dye-Sub, Epson 1280 inkjet, Epson Worforce 610 MFC
