What parts to Max Out my G50VT-X1 Asus?
mslaxmeter
4:40 PM
Minnesota
Hi I recently bought an Asus G50VT-X1 and I want to COMPLETELY max out its performance at any price.
Current G50VT-X1 Specs (modified from notebookreview.com specs)
Intel Core 2 Duo Processor P7450 (2.13GHz, 1066MHz FSB, 3MB L2 cache)
NVIDIA GeForce 9800M GS with 512MB of GDDR3 discrete video memory
15.6” WXGA Glossy LCD (1366x768)
Microsoft Windows Enterprise Edition 64-bit SP1
4GB RAM (4096MB) DDR2 (2 x 2048MB modules) 667mhz SO-DIMM
***Max of 8GB (despite official 4gb max, asus has told me 8 is supported)
320GB 7200RPM Seagate HD (2 total SATA ports available)
---How do you transfer the OS to another HDD without reinstall by disc?
8x Multi-Format Dual Layer DVDRW with LightScribeTechnology
Integrated 1.3 Megapixel Web Cam
6-Cell 11.1v 4800mAh battery, 120w power supply (Like only 5 minutes off AC power life...:( )
I am willing to go to most measures to upgrade these components / get pro to install them as long as they can be done safely.
Experimental suggestions are welcome too!!!!!
Links are greatly appreciated as well as full specs and full model id.
I want to optimize the computer in EVERY WAY however, I use it mostly for gaming.
I dont want suggestions for accesories like mice and cooling fans, ect, just internal hardware :)
Oh and If you know any OS's I can run alongside Win7 thatd be great besides ubuntu/linux os's... A relatively easy Hackintosh tutorial would be awesome too!!!
Ill get a max of a 1TB HDD and a like medium sized SSD. Both fast please.
Thanks SevenForums!
Ill give REP for helpful answers!
Windows 7 Enterprise 64-Bit SP1Core 2 Duo P74504GB / 8GB DDR2 SO-DIMM 667mhz (Can do 800mhz)NVIDIA GeForce 9800M GS
Asus G50VT-X1
Core 2 Duo P7450
Standard Motherboard/BIOS
Standard Sound Card/Speakers
15.6" WXVGA Display
1366x768
2 Available SATA Ports:
Port 1 : Standard HDD (Seagate 320gb 7200rpm 3mb l3 cache)
Port 2 : No Drive Installed
Standard Hardware Case
Internal Fan, Left side. Cooling mod (Cut out bottom grate)
Standard Keyboard, Numpad, NOT Backlit
Standard touchpad, centered w/ keyboard
Unknown
Led lights on lid, LED display abouve keyboard, Used computer, Mic is nonfunctional, 3 usb 2.0, 1 eSATA, card reader.
First thing:
Get an SSD. Intel, Samsung 830, or Crucial M4. Keep the HDD for storage if possible. Put the OS and your applications on the SSD. 80 to 128 GB should be a good size for the SSD.
You transfer the OS by cloning or imaging or by using a Paragon application that costs 20 dollars. I think it's Paragon Migrate or a similar name.
The upgrade to 8 GB RAM might make a difference in some circumstances, but don't expect to be overwhelmed.
Do the normal maintenance---defrag any spinning drives, install as few apps as possible, use a good antivirus and antimalware setup, etc.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
First thing:
Possible to do it for free? Burn to disc?
Asus G50VT-X1
Core 2 Duo P7450
15.6" WXVGA Display
1366x768
Unknown
Yes, you can do it for free with Macrium Reflect Free Edition:
Macrium Reflect FREE Edition - Information and download
A clone is a direct transfer in real time from drive A to drive B.
The image method requires that you make an image file of the existing drive, store it on another drive, and then restore that image file to the new drive.
Either can work. Either can fail. Success rate probably 90 plus percent. Either might cause you to cuss a while and wonder why you didn't spend the $20 on Paragon.
Imaging is the more common method.
Many would tell you to do a clean install from a USB drive if necessary.
1600 x 900
Antec Solo II
Pale Moon
Hehe im not too sure how to do much imagaing anda ll that I just want the os on a SSD but if you could give me alink thatd be great XD
Asus G50VT-X1
Core 2 Duo P7450
15.6" WXVGA Display
1366x768
Unknown
1600 x 900
Antec Solo II
Pale Moon
I noticed you have Windows Enterprise 64 bit installed. I would recommend contacting your I.T. department before doing anything to that computer.
Its not a business computer...just came with enterprise. I bought it used
Haha i am the it admin
Asus G50VT-X1
Core 2 Duo P7450
15.6" WXVGA Display
1366x768
Unknown
Besides adding an SSD, upgrade the CPU to an extreme CPU, the X9100 and then overclock on the fly with throttlestop. They are cheap on Ebay. 3.45GHZ 100% stable at full load at 1.275V or so. Also upgrade to the Forcecon DFS541305MH0T “F8U5" fan from the Delta one, more air flow. Use MX-2 thermal compound which has 8 year longevity.
Upgrade the firmware for the DVD-rom drive. This way it won't seek during windows boot, just at POST.
Since your original battery is worn out, you'll need to go aftermarket, go with 9 cell ones and make sure it can handle the load of the CPU and GPU on full, because I've had experience with one that would cut power without warning even if fully charged, if taxed hard.
windows 7
windows 7
To the best of my memory selling a computer with Windows 7 Enterprise installed is not legal.
