Windows 7: BIOS beep, PC posts, but red LED light on GPU and no monitor signal
29 Jul 2012   #11
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Almost. When you take out the 3 wires, use 2 of them and put them in the old cooler fan connector. Just make sure you have the black one in the same orientation as the original or the fan will spin the wrong way. You'll have an extra, tape it over so it won't touch anything else.
What I want you to end up with is a 2 pin connector on the new fan.
30 Jul 2012   #12
MelancholyRose
Windows 7 64-Bit Home Premium Service Pack 1
All right, hopefully I'll have a chance today to take a shot at it. I'll let you know how it went after I try it out.
Thanks for the tip, I didn't know those pins could be removed.
30 Jul 2012   #13
MelancholyRose
Plugged fan directly into card this time. Light is still red. Nothing's happening. The red light is still in the same place it was before, on the actual card. POST beep and everything, and the fan is running, but nothing else.
Here's some pictures of where the light is showing up. I don't know what else to attribute this to.
And this is the cooler on Newegg: http://www.newegg.com/Product/Produc...ero%20l2%20pro
And the fan IS running, so I know it's plugged in and everything. I put the right color pins in the right spots.
BIOS beep, PC posts, but red LED light on GPU and no monitor signal-img_0265.jpg   BIOS beep, PC posts, but red LED light on GPU and no monitor signal-img_0266.jpg   BIOS beep, PC posts, but red LED light on GPU and no monitor signal-img_0267.jpg
30 Jul 2012   #14
Britton30
Microsoft MVP
Don't take this the wrong way. Did you reconnect the monitor cable? Also try pulling the card and reinserting it to make sure it's fully seated. If this doesn't help, I'll have someone else look in here.
I'm not saying you are incompetent, I've done silly things like forgetting things, many times. I've also forgot to flip the PSU switch on.
30 Jul 2012   #15
MelancholyRose
Naw, I know you're not saying I'm incompetent. I'm not offended :P I've done silly things, too.
Yes, the monitor is connected.
I've tried re-seating many times, it doesn't work. I have it in as far as it'll go. It's screwed in and secure.
I've tired plugging it into both DVI slots, still doesn't help.
I know my PSU is switched on, because the rest of the computer boots just fine.
I've also tried using a different power cable for the card to see if maybe the cable I was using had a short, but that didn't work either.
I'm actually really concerned the VRAM coolers on the card may have caused damage or something. The cooler itself comes with a bunch of additional memory heatsinks that glue onto the chips.
30 Jul 2012   #16
TVeblen
More stupid questions:
Did you apply thermal paste to the heatsink?
There should be 4 LEDs on the card, from what I have read. At least the Sapphire 4800 series had 4. There should be numbers next to each LED. If D1601 is lit red it means a "critical temperature fault".
See post #14
Sapphire 4850 LED codes?
The other thing I think of, reading your thread and assuming you have made all the connections and installations correctly, is that the card was critically damaged when the original fan failed. I know that is not what you want to hear, but it remains a possibility regardless.
And I have a WAG:
Remove all of the installed RAM from the system and try booting with just one stick in the first RAM slot.
And for good measure you could also perform a Clear CMOS too.
Sounds far fetched but I have read posts where these actions have cleared the red LED!
30 Jul 2012   #17
MelancholyRose
Thermal paste came pre-applied on the heatsink, and I didn't touch it or remove it. I did clear off the previous thermal paste first before putting the new heatsink on.
Right after my other fan failed, my card was definitely still functioning just fine. I had run it once or twice to check the old fan (when it was still on the old heatsink) and the card would boot up and work, even with the failed fan in it, and I shut the PC off before the card could get too hot, just so it wouldn't damage it. Is it possible for it to completely die while it wasn't connected to the motherboard or being used? I imagine it could be possible, but was there something I might have done wrong?
When I have time I'll check the light and see what number the LED is and get back to you ASAP.
30 Jul 2012   #18
MelancholyRose
Looks like it's D4000.
And it looks like this person had the exact same problem as me, the very same cooler I have:
http://www.overclock.net/t/885790/xf...4000-light-red
30 Jul 2012   #19
Layback Bear
Windows 7 Pro. 64/SP-1
Just a though. Could the red light be on because the card no longer picks up the rpm's with a two wire connection. Their for the card thinks the fan isn't working. Because of that the video card is shutting it self down.
30 Jul 2012   #20
MelancholyRose
If all else fails with this cooler, I can try putting the old one back on. I had purchased a new fan and stuck it on there, and it's a 2-pin, but the plug didn't fit the connector, so I bought the new heatsink instead, figuring it might help with temperatures too in the long run. But now that I know I can pull the wires out of a plug and put them in another one, I can try that with the fan and see if it's the cooler or not.
The only problem with that would be, I wouldn't be able to re-attach the small memory heatsinks. If nothing else helps I'll try the old heatsink with the new fan on it. It would be nice if this cooler worked out though. Cost 35 bucks to order it.
Cut Signal After BIOS when Using OCTuner
Problem: --------------- 4 months ago i had experienced BSOD where playing call of duty ghosts while also moving a large 700Gb of data from SSD to HDD. The screen goes blank and then green then cuts power to the pc and then rebooted into BSOD Sometimes my mouse & keyboard played up and i...
General Discussion
satellite L850D wont boot to bios,no start beep.
I have tried to boot without the ram i get a series of beeps ,The screen is blank ,i tried shining a bright torch at the screen to see if i can see the bios page but nothing.:confused:
Installation & Setup
BIOS No Beep.
I have a acer m3910 desktop pc and its good.so about last year,i have change the gpu from hd5570 to gts450.my problem is that when i switch on my pc,there's no the 'beep' sound,everything is blank on the screen.So i remove my gpu,use the onboard graphics and i boot up fine.then i install back my...
General Discussion
ASUS Bios DRAM LED light codes
Ok so I'm doing a fresh installation of everything and when I reset the CMOS by jumper/taking battery out and putting it back in sometimes the DRAM LED will do one of two different things... Light up then go off Light up once, off for half a secon, then light up again then go off This isnt a...
Hardware & Devices
No signal to monitor
I have 2 Nvidia GTS 250s SLI together that have developed some sort of problem About half the time I boot the computer they don't send a signal to the monitor. If I unplug the connector and plug into a different port on one of the card it works fine until the next time I reboot and I have to move...
Graphic Cards
Start Up Bios Beep
Hi Guys, At start up this morning on my Laptop (VGN-NR360D), twice, I got constant beep... sort of 1-1-1-1-1-1. This was right at pressing the power button before the bios screen came up. The Third time it went into windows... the bios is a Phonix bios. I m trying to find some info on the...
Hardware & Devices
