Windows 7: BIOS beep, PC posts, but red LED light on GPU and no monitor signal
31 Jul 2012   #31
IIllytch321
I'm trying to get everyone to take note of the "Marked as solved" option. I think you, as the thread started, has to do it.
01 Aug 2012   #32
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Good to hear Rose, that was a curly one to say the least. It was a good experience for all of us. That's how I learn, by my own blunders.
Cut Signal After BIOS when Using OCTuner
Problem: --------------- 4 months ago i had experienced BSOD where playing call of duty ghosts while also moving a large 700Gb of data from SSD to HDD. The screen goes blank and then green then cuts power to the pc and then rebooted into BSOD Sometimes my mouse & keyboard played up and i...
General Discussion
satellite L850D wont boot to bios,no start beep.
I have tried to boot without the ram i get a series of beeps ,The screen is blank ,i tried shining a bright torch at the screen to see if i can see the bios page but nothing.:confused:
Installation & Setup
BIOS No Beep.
I have a acer m3910 desktop pc and its good.so about last year,i have change the gpu from hd5570 to gts450.my problem is that when i switch on my pc,there's no the 'beep' sound,everything is blank on the screen.So i remove my gpu,use the onboard graphics and i boot up fine.then i install back my...
General Discussion
ASUS Bios DRAM LED light codes
Ok so I'm doing a fresh installation of everything and when I reset the CMOS by jumper/taking battery out and putting it back in sometimes the DRAM LED will do one of two different things... Light up then go off Light up once, off for half a secon, then light up again then go off This isnt a...
Hardware & Devices
No signal to monitor
I have 2 Nvidia GTS 250s SLI together that have developed some sort of problem About half the time I boot the computer they don't send a signal to the monitor. If I unplug the connector and plug into a different port on one of the card it works fine until the next time I reboot and I have to move...
Graphic Cards
Start Up Bios Beep
Hi Guys, At start up this morning on my Laptop (VGN-NR360D), twice, I got constant beep... sort of 1-1-1-1-1-1. This was right at pressing the power button before the bios screen came up. The Third time it went into windows... the bios is a Phonix bios. I m trying to find some info on the...
Hardware & Devices
